Discreet but capable
- OlaGB
20 Mar 2018 11:17 #190623
by OlaGB
Replied by OlaGB on topic Discreet but capable
A 200hp tdi would kill youre drivetrain weekly...
A m16a vvt will cost you 400 pound + exhaust + remap.. Everything bolt on, and no MOT issues..
Would probably give you a wide 150-160nm 110-120hp curve..
If you got youre m13a ecu mapped to this setup, myself and several others would be interessed in buying in on the remap, if the tuner could flash our ecu's as well..
- Thank you received: 305
20 Mar 2018 13:09 #190626
by sniper
Replied by sniper on topic Discreet but capable
I just had a chat with a local motorsport outfit and am now pretty certain I will stay with the M13AA fitted. The throttle body set up and exhaust will cross over to a M16A if I find the 13 unreliable or overstretched.
More interestingly, they supply a very compact transfer box with a centre differential for rallycross cars, they are developing a low range gear set that would make it very usable in the jimny.
Full time 4x4 on tarmac, comes at a fair cost £4k ish but that combined with ATB diffs front and back would make for a go kart.
sniper
sniper
20 Mar 2018 13:45 - 20 Mar 2018 13:58 #190628
by sniper
The plan is finalised:-
Stage One - completed this month.
1. New front brakes, clean and adjust rears
2. New clutch
3. BFG AT's x 5
4. New KYB springs at standard height
5. Proflex 15mm spring seats
6. +25mm bump stops
7. AVO adjustable dampers +25mm
8. Rear shock relocate brackets
9. Rough country steering damper
Stage Two
1. Rear ATB differential
2. Front ATB differential
3. Exhaust
4. Throttle bodies and fuelling computer
5. Rolling road set up
Stage one has cost 2k to complete, each item on stage two will cost about 1k and will take me about a year to complete.
Engine mods at the far end of the project.... bummer but it's the way to do it. Chassis first, power second.
sniper
(oops. forgot the transfer box, if that pans out another 4k at the end)
2. New clutch
3. BFG AT's x 5
6. +25mm bump stops
Stage Two
3. Exhaust
sniper
Last edit: 20 Mar 2018 13:58 by sniper.
20 Mar 2018 16:00 #190629
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Discreet but capable
Only issue i can see,
Unles you have done some careful measuring , Longer rear dampers with the completely pointless repositioners will be to long and with trash themselves pretty quickly on compression.
20 Mar 2018 18:07 #190636
by sniper
Hi Jezz,
I got the +25mm dampers as I'm unsure about the final height, it will be either at +15mm or at +25mm. I have got +25mm bump stops and will carefully check travel when fitting. If I am concerned I will go to +25mm seats straight away. At £100 per corner I definitely don't want to damage the dampers. Thanks for the nod.
Busta, thanks for your input. I have had a think and am going stay with the M13AA, I have always liked high revving low cc engines and the planned modifications will all transfer to the M16A if I'm not happy.
sniper
sniper
20 Mar 2018 18:18 #190637
by sniper
I will happily share the results, if anybody wants to buy in on any part (i.e. the final map) I'm happy to oblige. It might get me a better deal and make the tuners work a bit sharper if they think there is more business to be had. The map will be specific to the ITB's and exhaust, so I don't know how much use it would be. (OlaGB)
sniper
sniper
Time to create page: 0.214 seconds
