Discreet but capable
11 Mar 2018 14:56 - 11 Mar 2018 15:45 #190269 by sniper
Replied by sniper on topic Discreet but capable
Thanks Riccy, I've run Koni adjustables for years on mini's but I decided to try AVO as I'd heard that soft side adjustment went further. If I don't like the AVO's, Koni is the next stop.
Springs worry me far more, just going to be wild stabs in the dark at makers and rates. I will be fitting my first guess in the next week or two and know there will be a significant improvement over the tired 65k existing set up. I will be very lucky to get it right on my first go and at £200 a chuck, getting it wrong will be a bugger.
Be much easier with some sort of adjustable platform or coil over setup.
Been looking at tyres again and rolling circumferences, my 215/70x15 are 2144mm which is a full 104mm bigger than the 205's they replaced,
The change in gearing is noticeable but manageable.
I'm looking at road tyres and 215/55x17 gives me 2040 r/c the same as the 205's originally on the car. This will put the gearing back to standard, I felt it was ok at standard just lost legs on the 2-3 change.
sniper
Last edit: 11 Mar 2018 15:45 by sniper. Reason: bit more
11 Mar 2018 21:14 #190285 by Riccy
Replied by Riccy on topic Discreet but capable
I should have mentioned the AVOs, its what i have just fitted. 24 click adjustment from virtually no damping right up to racecar hard. Also one of only 2 makes (that i know of), that are the smaller and correct 42mm body shock (Zanfi being the other, but not adjustable and more expensive). All others seem to be 50mm body, which catches the panhard bracket on the back of mine. 42mm is no problem and the AVOs are nothing short of brilliant.
The Koni's came to mind as being more of a sport based adjustable thing at standard ride height. they dont make any longer shocks for jimnys.
12 Mar 2018 07:40 #190300 by sniper
Thanks for the endorsement on the AVO's Riccy, I understand they are good gear but knowing they suit my application, takes a little worry away.
Springs, seats, rear shock brackets and a steering damper all waiting on the AVO's........
Like a kid, meccano for grown up's my wife calls it.
sniper
  • OlaGB
20 Mar 2018 07:16 #190620 by OlaGB
Replied by OlaGB on topic Discreet but capable
Following this thread for sure! The motor plans are really interesting.
A question tough; why are you going down the top HP route, and not aim for more torque? The track rigged swifts are tuned for high hp power, to get the speed they need..
I mean, if you want the best drivable offroad power, you want a flat curve that also has enough grunt to stay down at low rpm`s.. A M15a or M16a VVT conversion mght be a better place to start, when you anyway plan to go mapping on dyno, probably making more usable power, for maybe even less money?
20 Mar 2018 08:17 #190621 by sniper
Hi, torque is the gain I'm looking for, bhp will increase as a matter of course but the aim is an early entry onto the torque curve with peak torque being delivered as far down the rev range as we can. Sadly the boost in performance pushes peak torque further up the rev range, so a compromise will be made where peak power will be sacrificed for a smoother, earlier starting, earlier peaking torque curve.
I have done three "paper" builds and looked at cost v benefit, M13AA is in the car but will cost 3k to tune to 120hp. That will be mainly exhaust, TB's and mapping. It would rev like a bike engine and having a small cc engine suits me.
I have had a look at the VW diesel and can get this in the car at similar cost, I have had some experience with these lumps and know a few people running over 200 bhp and 350+ foot pounds of torque. They are very tuneable and can deliver enough torque to turn the globe.
Typing this is changing my mind, look at the two options.
Option 1, tune existing to 120hp and similar torques, stressed engine running near peak output, needing regular (3k) services.
Option 2, VW diesel that will provide all the power and torque that I could ever want, operating well within it's capabilities. Annual servicing.
Not really a choice, VW makes way more sense.............
I can take small bites at tuning the 1300 and progress through the tune, will be over time. A slowly developed car.
The VW swap would be a single hit, instant gratification and reliability.....
I'm going to wait and see what I end up with when the suspension is changed, the car will tell me what it wants...
Still waiting on the AVO dampers to move it forward.
sniper
20 Mar 2018 09:13 #190622 by Busta
Replied by Busta on topic Discreet but capable
I think a lot of people confuse 'moving the torque higher up the revs range' with reducing bottom end torque, when in reality you almost always increase torque throughout the rev range. It's just the most noticeable gain is at high rpms.
Your finished engine might have a 30% higher peak torque at higher revs, but it will also gain 15+% more torque everywhere else.
I hear what you say about the VW diesel, but you should also consider in implications it has on weight, gearing and drivetrain longevity as well as the fabrication needed to fit it, mount an intercooler etc. I'd sooner put in a bigger NA petrol than diesel. The Ford 2.0 zetec found in a Mk3 MX5, for example, almost doubles the standard Jimny's power and torque without weighing the same as a house and will slot into the engine bay very easily with the MX5 gearbox.
Time to create page: 0.208 seconds
