Help
Category:Howto - gen3
Revision as of 15:37, 13 May 2016 by
Mlines
talk
contribs
(Created blank page)
(diff) ← Older revision |
Latest revision
diff
Newer revision →
diff
Jump to navigation
Jump to search
Pages in category ‘Howto - gen3’
The following 52 pages are in this category, out of 52 total.
2
2WD-only Jimny to 4WD retrofit
4
4WD transmission failure - emergency measures
4WD transmission failure diagnostics
A
ABS System - Reading and Clearing Fault codes
Auxiliary battery tray installation
Axle mount repairs
B
Brake pipes and hoses replacement
C
Cabin filter change
Clutch release bearing wash
Clutch replacement
Computerized vehicle failure diagnostics
CV joint replacement
D
Dash board lamps change
Door open buzzer
Drive belts
F
Five identical tyres
Front brake pad change
Front speaker upgrade (Jimny 3)
Front wheel bearing replacement
Fuel tank removal and installation
G
Gearbox output end oil leak fix
Gearbox R72 rebuild
Gearbox swap - from R72 to R7ME
H
Headlight alarm buzzer installation
I
Interior works in cabin while trim is removed
K
King pin bearing change
M
Manual or fixed front wheel hub heads
O
Oil and air filter change
P
Power steering fluid change
R
Radio antenna replacement
Radio antenna upgrade
Radius arms and bush replacement
Rattling dash board fix
Rear brake shoes replacement
Rear cabin lamp installation
Rear engine mount change
Rear speaker installation (Jimny 3)
Rear upper spoiler installation
Rear wheel bearing replacement
S
Seat belt disconnected buzzer
Steering wheel change
T
Tie rod end replacement
Towing a Jimny
Transfer box conversion to Rock Lobster
Transfer box from Lada Niva installation
Transfer box from Suzuki SJ 410 - speedometer conversion
Transfer box from Suzuki SJ 41x installation
Transfer box swap - from button operated to lever operated
U
Universal joint replacement
W
Winch installation
Winch refurbishment
Window washing system - fluid leakage fix
Navigation menu
Personal tools
⧼userlogin⧽
Namespaces
Category
Discussion
Variants
Views
Read
View source
View history
Search
BigJimny Wiki
Wiki Home Page
BigJimny Home Page
BigJimny Forum
Bigjimny Web Shop
BigJimny Wiki Help
Important Disclaimers
Report content
Navigation
Wiki Home Page
Recent changes
Random page
What links here
Related changes
Special pages
Printable version
Permanent link
Page information
