Re:Re:Re:Re:Front axle oil seal.
- RayPaterson
- Visitor
Ray
- Roger Fairclough
- Thank you received: 194
The bottom bearing needs to be located onto the King Pin when you re-fit the inner hub. That way it can't fall out.
Roger
- Thank you received: 551
I have only ever done this job once, and like Roger said I used the correct seal from Martins Shop ^^^^^. So yes the correct seal works well, but yes you can damage them if you are not careful. The shaft splines can damage the seal lip if you rest the shaft on the seal and simply push it in. Its better to guide it in with care, that way it prevents any potential damage of any seal you use.
Once past the splines you are unlikely to damage it with bearing juggling, but plenty of sticky grease will hold the bottom bearing in place as you swear at it.
Unforunately its a do it again job, hopefully second times a winner.
- Thank you received: 1759
- RayPaterson
- Visitor
I guess I did damage it with that bit of wrestling it takes to get the shaft in and joint together.
I have sent for seals and that's a few hours work to try and get it right.
Just wondering which job takes the most time to replace an under £5 part!
Ray
Vacuum hub off
Remove circlip and square washer from splines
Wheel off
Brake caliper yoke off
Disc off
Label and disconnect vacuum hoses
Remoive the 4x 14mm head bolts that hold the stub axle on and pull the whole assembly out with the driveshaft
That gives you easy acess to the seal.
- Roger Fairclough
But if you have removed the steering knuckle to check or replace the bearings or outer weather proof seal then you start with the fitting of the oil seal into the axle housing. Then you replace the outer weather proof seal/s. Then refit/replace steering knuckle outer bearing races. Place top bearing into position and fit bottom race onto bottom bearing cap and loosely bolt to steering knuckle. Angle knuckle downwards and slide into position onto axle housing. Knuckle is lifted upwards after bottom bearing locates in outer race and top bearing cap located to fix knuckle into position. All shims replaced where they came from. Once the bottom bearing is fixed onto the cap it cannot fall out.
With the knuckle correctly assembled the drive shaft is offered up. Hold the stub axle so the the axle shaft is parallel to the axle case. Then slide the assembly into the case. A smear of grease onto the oil seal and that part of the shaft that rotates within the seal is good practice.
Roger
- RayPaterson
- Visitor
A couple of quick questions..
Is this the tool I will need to do the job without taking off the kingpins? www.bigjimny.com/store/hub-nut-tool.html
Can I easily get a replacement for the circlip that holds the square washer on? Would probably be easier to remove if I don't have to save it
Thanks
Ray
- Roger Fairclough
If you don't want to dismantle the king pins then you must start by removing the hub and this means using the special tool.
So, in sequence, remove wheel, caliper, brake disc, outer hub with bearings - using special tool - inner hub, drive shaft. This gives you access to the inside of the knuckle and the oil seal. When you have got this far, take a good look at the condition of the grease. Is it milky in colour? This is a sign of water contamination. If it glints it is probably metal fragments and if it is dirty it's probably got dirt in it. For the circlip try Martin or your dealer.
On a personal note I would always strip out the lot. Weather seals, inner seals, wheel bearings, kingpins. Strip out the lot, clean it all and refit/replace with fresh grease and settings. But that's me.
Roger
RayPaterson wrote: Thank you Roger and Busta,
Thanks
Ray
The tool is only needed to change the wheel bearing (and associated Spindle bush). It is not needed for any work around the hub, including Kingpins and CV joint work.
- RayPaterson
- Visitor
Ray
