Re:Re:Re:Re:Front axle oil seal.
- Roger Fairclough
- Thank you received: 225
19 Feb 2021 11:30 #232988
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Front axle oil seal.
Whilst I think about it, would someone care to tell me how a king pin bearing can fall out when been re-assembled?
Roger
Roger
19 Feb 2021 12:53 #232991
Replied by jackonlyjack on topic Re:Front axle oil seal.
Nothing holding the bearing in place apart from grease
The hub slides on into place then it holds the bearings in
King pins slide through the hub into bearings
- Roger Fairclough
19 Feb 2021 14:21 #232993
by Roger Fairclough
From memory when I rebuilt my SJ 413 hubs the bottom king pin was assembled with the bearing in place on the pin. With the top bearing in place, you offered up the knuckle , bottom first until bottom bearing slides into position and then you push the top into position. At no time can the bottom bearing fall out.
Is this not possible with later marks?
Roger
Roger
- Thank you received: 1998
19 Feb 2021 18:09 #233004
Replied by Lambert on topic Re:Front axle oil seal.
There isn't enough clearance between the knuckle and the chalice.
19 Feb 2021 19:26 #233008
by Busta
Replied by Busta on topic Re:Front axle oil seal.
"Chalice"- good word!
Roger, access to the bolt heads isn't ideal. I could get a 1/4" drive socket on them with a short extension but not a 1/2". Next time I'll replace them with socket caps.
- Roger Fairclough
19 Feb 2021 19:45 #233009
by Roger Fairclough
No idea what a Chalice does on a Jimny.
Busta, how about a short 3/8" socket with a wobble drive extension?
Roger
Roger
Time to create page: 0.355 seconds
