Re:Re:Re:Re:Front axle oil seal.
18 Feb 2021 22:12 #232974 by mlines
Replied by mlines on topic Re:Front axle oil seal.
Not 100% sure which four bolts you mean but there are 4 bolts behind the disc which can be accessed with a spanner. However they are often corroded in place. Far simpler to undo the king pin bearings and take the whole this off as a whole unit
The following user(s) said Thank You: rayz_x
18 Feb 2021 22:23 #232975 by Busta
Replied by Busta on topic Re:Front axle oil seal.
Having recently swapped a few front diffs around, and then repeated the process to replace non genuine halfshaft seals with genuine, I found the method in my video above far quicker and easier than removing the kingpins. I'm familiar with both methods. On my non-ABS Jimnys acess to remove corroded bolts with a chisel was fine. They are the same as the prop bolts if you need spares.
19 Feb 2021 06:03 #232978 by Lambert
Replied by Lambert on topic Re:Front axle oil seal.
So you are splitting the front off the knuckle? Sounds like an easy way to get contamination in the wheel bearings to me, I would prefer to take the knuckle off whole if I could. Also it means that all nuts and bolts are accessible with rattle guns and 6 point sockets.
19 Feb 2021 07:57 #232981 by Busta
If you want to call it that, yes. I'd call it the stub axle. I'm not sure how it would lead to contaminating the wheel bearing unless you were to store the removed pieces in a puddle? It saves a lot of faff with tiny swivel seal bolts and the bottom kingpin bearing falling out. Everything comes off in small manageable pieces. When changing a diff it saves a lot of time, same for if you ever need to replace a CV joint.
I've done my fair share of king pin bearings so I'm not green to this! There's more than one way to skin a cat.
19 Feb 2021 10:21 #232984 by Lambert
Definitely plenty of was to skin things and if you are happy with it I'm not going to judge.
19 Feb 2021 11:17 #232987 by Roger Fairclough
A picture is worth a thousand words, so thank you Busta.
The comment re: contamination of the wheel bearing is odd as the axle hub, which contains the bearing, has not been disturbed from it's position on the knuckle spindle. As the vacuum cover/flange is only removed to access and remove the CV joint retaining circlip, it could have been replaced immediately after the circlip had been removed obviating the chance of contamination getting in during further work.
The picture shows cut outs on the axle hub which would allow a socket to be used to loosen the 4x14 mm bolts that secure the knuckle spindle to the steering knuckle.
Some people may feel that I have been pedantic in my questioning of procedure but there are reasons. If access to the 4 bolts is not possible with a socket but only a spanner, then the correct torque setting on re-fix cannot be applied. Also if the whole unit is removed by stripping out the king pins, then the chance of damage to the new oil seal is greater as you will not be able to enter the half shaft into the axle casing at the correct angle. Again you might feel that I am being fussy but I work on the basis "do it once, do it right".
Roger
Time to create page: 0.209 seconds
