Re:Re:Re:Re:Front axle oil seal.
- Roger Fairclough
- Thank you received: 225
18 Feb 2021 15:09 #232949
by Roger Fairclough
Replied by Roger Fairclough on topic Front axle oil seal.
Martin.
Am I to assume that if you remove the brake disc you gain access to the bolts that mount the knuckle spindle to the steering knuckle and that removal of these bolts will enable you to remove the knuckle spindle and the axle hub as a unit?
Roger
Roger
- Thank you received: 1995
18 Feb 2021 17:17 #232956
Replied by Lambert on topic Front axle oil seal.
In order to replace the inner axle oil seal you have to remove the cv joint and half shafts. This is not possible without removing the steering knuckle which in turn is not possible without removing the kingpins and bearings. It is possible to do this with the abs sensor in place with care but the rest of the brakes have to be removed too. With practice this is possible on both sides of the car in a morning and 2 cups of tea.
- Roger Fairclough
18 Feb 2021 19:06 #232966
by Roger Fairclough
Lambert.
Your answer does not agree with Busta's. Maybe you would like to answer the question I put to Martin.
Roger
Roger
18 Feb 2021 19:27 #232967
The original question regards the inner oil seal and suspects it was damaged in the process of repairing the kingpin bearings. The inner oil seal runs on the half shaft inboard of the cv joint therefore it is physically impossible to replace the inner oil seal with removing the half shafts. This does not include disturbing the wheel bearings or stub shafts beyond removing the steering knuckle assembly as a whole. It does not require the special hub nut tool.
- Roger Fairclough
18 Feb 2021 20:45 #232971
by Roger Fairclough
Lambert.
You still haven't answered my question, so I will ask it in a slightly different manner.
Can the 4 bolts that connect the knuckle spindle to the steering knuckle be accessed without removing the axle hub.
Roger
Roger
18 Feb 2021 22:08 #232973
by Busta
Replied by Busta on topic Front axle oil seal.
Here you go.
I have assumed that on ABS models the sensor ring prevents access to the bolts that holt the stuib axle on, but I've never done one to know for sure. If not the hub nut tool is not necessary.
Time to create page: 0.208 seconds
