Suspension question
- Seawolfvarna
- Visitor
MigCooper wrote: I have the standard rims with no offset, but I fitted 32mm spacers
Hi MigCooper
I ordered already steel wheels with -30 offset. In that case I believe, that if you fit your 30" with 32mm spacers on original wheels, than may be I will be able to fix 235/75/R15.
Did you try already your monster.
How is power performance? Do you will some lack of power?
Cheers
- Monkey
- Visitor
Hi MigCooper
Cheers
You are going to have BIG scrubbing issues with ANY size tyre that you choose cus of the huge off set.
Migcooper: I think you should consider buying some new wider rims for those 30"sx9.5 here in AUS it it illegal to run anything bigger than a 215's on a 5.5" wide rim. You will also get more life out of your tyres, say with a 15x7" rim.
- Seawolfvarna
- Visitor
Monkey wrote:
Hi MigCooper
Cheers
The rims are with following specifications:
7" x 15" 5x139.7x 110 ET -30
So in that case is it possible to avoid wheel spacers?
Yours
Nick
- Monkey
- Visitor
Seawolfvarna wrote:
Monkey wrote:
Hi MigCooper
Cheers
Yours
Nick
Yes i run 15x7's -13 and even that feels very stable, but you are going to need to trim your guards due to the size of your off set...
- Seawolfvarna
- Visitor
I will do it!
Cheers
- Seawolfvarna
- Visitor
31"can be fitted there or not?
Thank you
- darthloachie
- Visitor
Seawolfvarna wrote: Did somebody know, what is the max size of tyres which you can fit on 7"x15" rims?
Thank you
yes
