Suspension question
- Monkey
- Visitor
MigCooper wrote: lol
kind going slow down hill that is my biggest worry ..... Thats where I felt the low range was more needed
I haven;t really had issue there... but i never lock up when going down hills cus of the ABS
- Seawolfvarna
- Visitor
The pluses are clear, what bout the minuses?
Cheers
- Seawolfvarna
- Visitor
MigCooper wrote: Got the tyres fitted
I've fitted 30" malatesta kaiman and what a diferrence it makes and the jimny looks now
Did some trimming on the arches and bumpers and that was all, but will have to flex the suspension to see if the tires will rub anywhere ....
Well done
Wish you many, many nice adventures with new tyres!
Cheers
- Seawolfvarna
- Visitor
Disregards of money costs.
Thank you!
- Thank you received: 6
Well done
Cheers
Thanks ..... they should be great on mud lets see what will they be up to
3" Spring Lift + 1" Spacers / ES300 Shockers / TJM Snorkel / Extended Brake Lines / Castor Correction Bushes / Adjustable Panhard Rods / 30" Kaiman / 4.16 Redacted lobster / No Anti Roll Bar / Rock Sliders (Home made) / Diff Guards from ORA / 32mm Spacers /...
Seawolfvarna wrote: Does any body know the way to modify our own Suzuki Jimny T-case, without to use any donor from 410 or 413?
Thank you!
Yes you can get gears from Redacted that will give you reduction of 25%, but I heard bad things about this before. you will also need to change the T-Case chain another 300£ ish ... and some people complained about braking something, cant remember what ...
- Seawolfvarna
- Visitor
Did you measure the weight of tyres without rims,before you fix them?
It is interesting to know how much they weight?
Just another point. The spare tyre will not fit the standard mount .
- Seawolfvarna
- Visitor
MigCooper wrote: no, did not and they are all in the rims now.
What kind of rims you have? How much is your offset?
Are you using some wheel spacers as well?
Thanks for sharing.
- Thank you received: 153
Have a look at this
www.bits4vits.co.uk/store/vitara-/-x90/s...racket/prod_370.html
Have a look at this
Thanks supergaz .... postage is a killer for me 26£
