Re:Re:Re:Jimny pulling to right
- Thank you received: 498
I did adjust it too much at first and that did seem to make it pull to the right, but backed off the drag link a bit and the steering wheel is almost perfectly straight and no pulling. I haven't bothered trying to get it absolutely spot on as it would be such a small adjustment I would probably end up going too far again.
@lambert the power steering is electric .
- Thank you received: 1795
My simple thought process on it.
- lookonimages
- Thank you received: 64
Lambert, yes. I will take it back to the steering specilist in cape town, but that will be only next week some time when I go to Cape Town again.Lambert wrote: Thanks mate. So it being electric there more than a chance that it knows where centre should be and it's attempting to maintain that position. It will probably have some feedback sensors which may be confused and need recalibration or something like that. Either way it's sounding like a controller issue rather than an alignment issue. Might be worth having a comprehensive code reading session see if anything thinks it's unhappy.
When they had it hooked up last week to their computor it showed the parameters is in line with suzuki (but that is parameters for standard Jimny) he showed the data reader screen data to me, but I guess it is correct set to "standard" position. Maybe they need to adjust the "standard" parameters to now correct for the lift and thus correct the steering wheel.
Their is something that move the steering wheel to a specific position the moment the wheels starting to rotate.
So on the steering data reader and electronic settings, i will only be able to give feedback next week then. But there sure is some setting for that "rest" position, I am pretty sure now.
- lookonimages
So it seems the steering angle sensor position can be set / recalibrate for electric steering assist systems - if you have to tools.
Nit much on Jimny's but lots on other cars that have had this technology for much longer.
The guy in Capetown have simmilar diagnostics tool (tablet type) as in video below so maybe we can be lucky next week.
Google "steering angle sensor position"
- Dirtbird
- Visitor
I think my self the power steering is your problem.
- lookonimages
No it is not steering box related.Dirtbird wrote: Yeah, I was wondering could it be the power steering - I had a Hilux that gave me weeks of steering problems wasn't until I looked at the power steering box that I realized it was slightly loose. I knew the previous owner and asked him and he told me he had reinstalled a secondhand power steering box (I discovered he had not tightened up the bolts fully ) Hence the poor steering...
Vehicle was all of today at power steering place. Vehicle run perfect straight now albeit the steering wheel still have a 5-10 degree slight offcentre. They have been able to remove most of "off centre" position.
I decided to live with that. Nough money spend to try and get it "perfect"
When it goes for next service at suzuki, i will ask them to check it, maybe they can set the default resting place of the steering sensors or inspect the steering sensors itself.
- Dirtbird
- Visitor
Ok well i think its the kind of thing your just going to forget about after a while , Id be happy with a Jimny to drive right now , any condition and any varient. . But youve got it sorted the main thing really.
Sent from my VOG-L09 using Tapatalk
- Dirtbird
- Visitor
