Re:Re:Re:Jimny pulling to right
- lookonimages
- Thank you received: 64
That is 100% correct.HFPE wrote: Have seen talk of resetting/calibrating magnets in the power steering via obd? Not sure if this might be the issue.
Sent from my VOG-L09 using Tapatalk
Just to update everyone, after some more work done today.
I now have full confirmation that it can be calibrated / reset and have confirmation that 2 jimny's steering angle position sensors have been recalibrated successfully by 3rd party, but it is very far from me.
Anyway for now I will drive like that, till it goes for its service at suzuki next month. Will then ask suzuki if they will do the steering angle sensor position recalibration.
We have now very conclusive info what is wrong and how to correct.
Thanks all for helping and trying to resolve issue. Much appreciated.
- Thank you received: 82
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
- Thank you received: 1755
- lookonimages
Thanks Rob & Lynton from Dessol, who made a huge effort to get me sorted. This is not a product defect or install defect. Normally it is just a case of install the lift kit and adjust steering rack rod as per martin's instructional video. Thanks again Martin for your videos.
My vehicle seem to be one of those odd ones out that need steering angle sensor recalibrated.
I should have contacted them from day one instead of running around trying to sort this myself.
if it is them fair play to them for helping you.
- lookonimages
Yes that is them.Dirtbird wrote: Are these the people who helped you des-sol.co.za/suspension-gen-3/
- lookonimages
- lookonimages
Yes indeed, I do use sz viewer app onmy phone connected vua Bluetooth.Dirtbird wrote: Lookonimages are you using SZ phone app and blue tooh to your DOB2 dongle?
- MrPaynterZA
- Visitor
Do you by any chance have a link to the OBD2 reader you're using?
- lookonimages
post=238633]That's awesome @lookonimages,
[/quote]
Any elm327 should work.
I opted for the viecar, just because reviews were good and it said Andoid/IOS compatible
www.takealot.com/viecar-4-0-elm327-obd2-...ALw_wcB&gclsrc=aw.ds
There are cheaper alternatives like these
www.takealot.com/ctech-elm327-bluetooth-...ce-tool/PLID54512410
but was not happy of fine print below
