235/85-16 on Stock Suspension, No Body Lift & All Original Panels
- Rabid Rhino
- Elite Member
- Thank you received: 33
15 Apr 2022 00:12 - 15 Apr 2022 00:14 #242893
by Rabid Rhino
Replied by Rabid Rhino on topic 235/85-16 on Stock Suspension, No Body Lift & All Original Panels
Once tha chassis had tried from its jet washing I treated it to some internal rust protection.
I read the reviews and the only repeat complaint I saw about the stuff I wanted was the plastic spray tube was always kinked & split in the middle of the 36" tube. But they were old reviews im sure they'd change the tube or packaging by the time I ordered so as not to have the same problem. Nope. Kinked and split the later I didn't see until I started spraying. By then the tube was all oily and duct tape wouldn't stick to it. (Oh well twice the spray coating.)
Last edit: 15 Apr 2022 00:14 by Rabid Rhino.
- Rabid Rhino
- Elite Member
15 Apr 2022 00:33 #242894
by Rabid Rhino
With the inside of the chassis rust protected it was time to move onto the ends in preparation for the front and rear bumpers sourced from aliexpress (China) seen here in their boxes.
The partial extent of my hoard preparation with extra bits & bobs.
- Rabid Rhino
- Elite Member
15 Apr 2022 00:53 #242895
by Rabid Rhino
Time to open the big boxes..smaller box first.
The front.
I'm not alone in not knowing what these parts were for.
Didn't bother fitting the crush cans. It's not as if we could see any use for them. Infact I think they would need to be cut off.
The front.
- Rabid Rhino
- Elite Member
15 Apr 2022 01:39 - 15 Apr 2022 01:43 #242896
by Rabid Rhino
No instructions!!!
Time for those childhood years of playing with mechano to pay off.
Dean decided it was best to see what would be needed to add onto the chassis first so we offered upp the lower mounts which kind of aligned.
Fitted the center section & swung it top into place after reinforcing the top & sides of the chassis ends
Last edit: 15 Apr 2022 01:43 by Rabid Rhino.
- Rabid Rhino
- Elite Member
15 Apr 2022 01:58 #242897
by Rabid Rhino
Time to put the main bumper on.
this is where it got frustrating.... really frustrating.
The bumper just wouldn't line up. It was too far forward but the centre section it was coming off was right because the the chassis brackets it was mounted on were right..
There was 1" up & down adjustment and 1" forwards & backwsrds but it wasn't enough. The whole back edge was hitting the lower slam panel.
- Rabid Rhino
- Elite Member
15 Apr 2022 05:14 - 15 Apr 2022 05:18 #242898
by Rabid Rhino
This was the area where this "bolt-on" kit was hitting, we just didn't know why.E also couldn't figure out why the bumper lined up slightly better on the cars right than left.
Almost a 1" wide strip was taken off
And the fit was closer.
Dreaming of 235s
Even fitted some fog lights I found on ebay that kind of matched the headlights.
Dreaming of 235s
Last edit: 15 Apr 2022 05:18 by Rabid Rhino.
