235/85-16 on Stock Suspension, No Body Lift & All Original Panels
06 Apr 2022 06:13 - 06 Apr 2022 06:15 #242770 by Rabid Rhino
The Ultimate Question of everything Suzuki Jimny...
Whats the biggest tyres you can fit on stock suspension, no body lift and only minor trimming of the plastic arches with a little prying of the inner sheet metal  ?
The Ultimate Answer is not 42 but 32".... well 235/85-16 to be specific which are just under 32".
Yes on Stock Suspension & No Body Lift ! (With only Minor Trimming of all original panels & trim, keeping 99% & the Slightest Bit of Persuasion with a prybar and limited repetitive percussive alignment with a BFH.
Last edit: 06 Apr 2022 06:15 by Rabid Rhino.
06 Apr 2022 06:21 #242771 by Lambert
Oh this is going to be good! We already have a Guide reference, yay!
06 Apr 2022 10:01 #242774 by Busta
I look forward to seeing what you've done. That's the modern equivalent of 7.50r16, which I've always thought would be a good size on a standard Jimny.
I've been thinking 205/85r16 could be done, but I haven't been able to find any sensibly priced 5.5j16 rims to put them on.
08 Apr 2022 02:34 #242789 by Rabid Rhino
Correction
I might have got it wrong on the tire size: 235/85-16.
My concern, as on all builds, was clearance of the front tyres against the fire wall.
I might have to adjust the size & my ambitions.
08 Apr 2022 03:50 #242791 by Lambert
I think it was Dave with his boogie build that used offset castor correction bushes to move forward the front axle a little to get clearance?
08 Apr 2022 11:17 #242792 by Busta
Others have re-drilled the radius arm brackets on the chassis to move the front axle forwards slightly.
Time to create page: 0.241 seconds
