- Thank you received: 489
04 Aug 2021 20:35 #237304
Replied by DrRobin on topic Re:Dave's la(te)st buggy build...
That’s a nice Jimny sized lane and great video too, very entertaining.
Robin
Robin
- Thank you received: 923
04 Aug 2021 21:59 #237308
Replied by X8GGY on topic Re:Dave's la(te)st buggy build...
04 Aug 2021 22:06 #237309
A few favourites -
Whoops! Notice the dent in the door pillar
Sorry? What? They're all photos of the buggy?... Of course! :lol:
You'll have to read the blog for the rest
05 Aug 2021 05:27 #237310
by Old Neil
Replied by Old Neil on topic Re:Re:Dave's la(te)st buggy build...
Amazing achievement Dave, looks like a real weapon
05 Aug 2021 06:47 #237311
Replied by X8GGY on topic Re:Re:Dave's la(te)st buggy build...
Thanks Neil
05 Aug 2021 16:01 #237330
Replied by Riccy on topic Re:Re:Dave's la(te)st buggy build...
Good blog Dave
05 Aug 2021 16:30 #237331
by gv42
Replied by gv42 on topic Re:Dave's la(te)st buggy build...
Dave's blog and a beer is good
06 Aug 2021 05:52 #237340
Thanks Riccy and Mark (GV42) !
Back to blogging!
I'll start planning the next route this weekend, as it looks like a wet Sunday
Back to blogging!
11 Aug 2021 10:10 - 13 Aug 2021 13:49 #237481
Sunday gone wasn't too nice, so I had the day off... and sat and plotted the next couple of trips...
I started by dropping points on the places I wanted to visit / drive -
Covering a chunk of the map SW of Denbigh on the OS 116 map -
So that gave me -
A Wednesday Wander...
And a full Sunday...
But It's overcast this morning and threatening rain this afternoon, and Sunday doesn't look great as yet either...
So they are plotted, I'm just waiting for some better weather... in August?! Who's idea was it to build a buggy? :lol:
Back in the garage then?
So that gave me -
Last edit: 13 Aug 2021 13:49 by X8GGY.
15 Aug 2021 14:50 - 15 Aug 2021 15:02 #237569
Mixed feelings today The Jimny Jauntz group were out greenlaning today locally to me, but for reasons I won't go into I'm no longer in the group, so I woke up a little grumpy at the thought of them having a fun day out around me somewhere, but the weather didn't look too good on the forecasts, so I decided to have a day maintaining the Boogie...
Starting with a clean! For some reasons it was full of the remnants of undergrowth?! :lol:
Everywhere!
It was the handbrake I was trying to get to! :lol:
I grabbed the spare handbrake lever I have in the garage for the next buggy project, and found the right socket to go on the adjuster...
This is a Halfords Professional "Torq" Kit (I have a bigger set too. tool magpie! ) these are designed to allow the bolt / threaded bar to run up the shank of the socket set, so it never tops out in the socket, and can actually go right through the handle... so ideal for the handbrake adjuster...
Adjusted up, it had always been a little loose, but had got worse, probably as things bedded in after the Boogie has been used a bit...
Next job... the passenger side soft-top roof bracket had disintigrated!
Driver's side for comparison...
Ahh, yes, that's proper buggered!
Best make a new one then? :lol: 42mm hole centres...
I struggled to get the pivot pin off, so ended up cutting the ends off and trying to drill it out, 6mm drill then...
But it wouldn't come out
It started raining heavily, so I took the whole soft-top hoop off. covered the buggy, and moved inside the garage...
Felt vindicated at this point that it wouldn't have been much fun greenlaning with the other lads of the group or on my own, with a buggy with only half-doors and no back... Who's idea was it to (finally) build a buggy? And I thought it was supposed to be "summer", August isn't it?! LOL :lol:
I still couldn't get the pivot pin out
So I got a matching piece of tube out of the metal bin in the corner, and drilled it 6.5mm for a new pivot hole...
And then cut the end off the original soft-top hoop, and the end off my new piece of tube so that the length matched the original... I tried to find a piece of bar to go inside to strengthen the join, but eventually cut the head off a 10mm bolt as that was the right diameter... there's a photo of it later...
Then some box section was also pulled out of the metal bin...
Drill a few holes in it...
Draw some lines and then follow them with a slitting disk in the angle grinder...
And then shape into a new end foot with the replacement end of the soft-top hoop bolted in it too... There's the cut off bolt inside for strengthening
Test Fit
AH?! We're "only" allowed twenty photos on a post?!
Ummm, ok... Fast Forward...
Weld it up, grind it back, paint...
And refit! Job done!
I'll refit the fabric roof when the paint dries...
Everywhere!
Test Fit
Last edit: 15 Aug 2021 15:02 by X8GGY.
- Thank you received: 1811
15 Aug 2021 16:26 #237571
Replied by Lambert on topic Re:Dave's la(te)st buggy build...
That's way cleaner than mine!
29 Aug 2021 21:02 #238000
Out today for the first time with Alan in the buggy -
jimnybuggy.com/2021/08/29/alans-first-trip-29-08-21/
Didn't end to well, but was a great day out, and it'll soon be fixed and ready for the next trip out...
Sunday the 12th with Brett's group if I don't get out before then again...
Time to create page: 0.296 seconds
