- Thank you received: 923
jackonlyjack wrote: Dave do you not have a dremel speed click
You're missing out
Had to Google that JOJ...!
Ah, yes, the original set had that, but this box was a cheaper brand from Argos -
www.argos.co.uk/product/3112562?clickSR=...0accessories:5:327:1
A lot more for your money than -
www.argos.co.uk/product/7113921?clickSR=slp:term:dremel:1:5:1
And a tenner cheaper...
I'd written a list while on the till in the shop in the week...
A few little jobs to do before stripping a lot of the parts off and sanding everything down ready for paint soon, after the windscreen has been removed...
I started by drilling and riv-nut'ing the mirror guard(s) on... I drilled the top and bottom holes and riv-nut'ed the two in to hold the guard in position to drill all the rest, and then started riv-nut'ing the rest... until one of the riv-nuts jammed in the gun and I struggled for a while to get the gun out of it, and ruined the thread on the head doing it... so I'll have to order a new one... I've had it a while though, so it's done a good few in it's life,,, Ho-Hum! So I had to leave that and carry on with other items on the list...
Drilled, cut and shaped the mounting hole for the the other side repeater in the bonnet edge on the driver's side...
I then filled the edges of the (Keithy-made) bonnet vents and the pastie-pan with silicon sealent, and also tidied up the inside inner edges of the bonnet and silicon'ed that to make it neater, again, ready for paint...
I then drilled the front number plate and then the mounts in the front bumper(ette)...
And then the same in the back... Still need to drill and (temporary before paint) mount the two LED number plate lights...
Also during the day I'd give the spade of the ground anchor's mount three coats of silver Hammerite and then bolted that in place at the end of the day too...
Oh, and also drilled and (four) bolted the fake jerry can in place (that holds the winching Quick Strop ready for use)
So that was half the items off the list More on Wednesday... Must order a new Riv-Nut gun (one that does 8mm threaded holes if possible, as my old one only went up to 6mm), two packs of sanding "sponges" are due to arrive on Wednesday too, so I'll start sanding everything back ready for final paint on Sunday (the sanding that is, not the painting) Must ring the local friendly windscreen company too to ask them to come and whip the old windscreen out for me too...
Dave
- Thank you received: 178
Thinking about colour(s)... Blue would make things easier, but I've already bought some JCB-Yellow paint...
What about...
Painting the body tub and the bonnet blue, and all the additioanl "buggy / cage" bits yellow...?
What do you think?...
X8GGY wrote: Sat staring at the Boogie today during a cuppa-break...
What about...
Good and bright, if a bit Ikea colours
Maybe you could get them as a sponsor?
- Thank you received: 1761
IKEA meets the Subaru Racing Team...
Alan's pointed out (by email, he reads here but doesn't post) that my MOT man won't like the spacing of my number plates...
When it goes for MOT it will still have the original registration, and hence these plates...
- Thank you received: 116
maverick wrote: Looking good Mister
BRETT! Your account has been hacked, and someone has left a nice, un-sarcastic comment!
Jalapeño, IISY?
Started with a little lie-in, cooked breakfast, and then walked the Labradors...
Partly as it was my Birthday today... I'm sure those balloons are the wrong way round though?!
Anyway, the ladies went shopping for even more Christmas decorations, and they spent the day turning the house into a Grotto, as I retreated to the sanity of the garage...
My new / replacement Riv-Nut gun had arrived in the week, so I started with that... and then pushed the buggy across the garage (it's on dollies) and then marked, drilled and Riv-Nut'ed the driver's side guard too...
And then whilst also doing the other jobs to follow, I gave the mirror guards two coats of black Hammerite paint through-out the day...
And also painted around (half of the edge) where the Keithy-made bonnet vents are going to sit and inside the cut holes in the bonnet...
And then went and asked the missus if she had an old sheet I could have to mask off the engine bay while I bed-liner'd the inside of the bonnet...
I then I turned my attention back to the door cards... you may remember I'd already made the cardboard templates? Today's job was to work out how to relocate the door handles...
They'll sit in holes cut in the aluminium chequer plate door cards, but lower than Suzuki envisaged
Back to the original door cards to draw a template within the handle cut-out...
And then transfer that to a small square of cardboard...
Cut an oversize square hole in the doorcard carboard template and then align the two templates and draw within the square...
Then cut the door handle template piece to shape and parcel-tape it in place... and then refit it all to test, making sure the handle can be poked through the chequer-plate version when it is made, with the bent bit to resemble a step in the half door... fidly.. but it'll all work...
I'll have to do the same with the driver's side later, to make sure the door-opening metal rod is tight where the handle is positioned...
I'll also have to mount a bar within each door for the handle to be self-tapper'ed to...
It's getting there! Nice to get some paint on it...! In the next couple of weeks I want to sand the exterior down and start painting it, but first need to strip the seats out, mask everything off, and bedliner inside the cab floor first (to avoid any overspray onto the body)...
Now back in the house for this Blog, Bon Jovi and Beer... my youngest daughter fell for all the hints and got me Bpn Jovi's new "2020" CD for my birthday... now it's time for a hot shower and another beer in it (!) and then a nice piece of steak and all the trimmings, and a nice bottle of Faustino, my favourite red wine, which arrived in the post from our eldest daughter who couldn't get home for the weekend due to the English lockdown... but we'll chat to her later over Facetime... a Happy Birthday indeed
Cheers All!
