Ulysses
  • Dirtbird
22 Aug 2021 21:23 #237799 by Dirtbird
Replied by Dirtbird on topic Ulysses
Dave you are welcome, those old masks were in a well worn state, that should make things much better for you
Riccy while your at it .........Bump stops front and back, a clutch dosent have to be anything special ora kit something from  Blue Print would be fine,
Not sure if your asking me what to recommend there?
Here's what I have in Ulysses:
Front Bumps are Terrafirma air bumps with the old ones drilled out to fit them inside the springs
Rear bumps are originals with a 2" extension made from some left over scaffold tube
Clutch is an Exedy safari tuff from Martin
Hope that helps
Riccy yes spot on .
  • Riccy
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
04 Sep 2021 15:26 #238214 by Riccy
Replied by Riccy on topic Ulysses
Bit of programmed maintenance today.
Up on the ramps and set the rocklobster transfer box off draining the oil and remove the rear prop while there.
When I did the new gearset in the rocklobster box I noticed the rear prop had play in the UJs. I stuffed it full of grease and ordered some new UJs for it from Firow (the people who make the HD jimnybits props). Next day 2 shiny new sets arrived.
Much fighting to get the old C clips off and then it was nice and easy to swap and grease up the new ones. Only a small thing, but it needed doing.
While I was under there I measured up the UJs for the SJ intermediate prop and they are 25x64 size. Trawl on the internet found some for less than £8 each (and greaseable ones too), so they are ordered for another day.
Laning on Sunday 12th around Shropshire to look forwards to
04 Sep 2021 15:51 #238216 by Lambert
Replied by Lambert on topic Ulysses
Nothing worse than a none functional shaft!
  • Riccy
  • Banned
  • Banned
11 Sep 2021 15:04 #238471 by Riccy
Pah! more problems. Today I was meant to be driving down to over night at Brett's house, before 'laning tomorrow. Set off and over a bump in the road. Lots of loud rattling & banging noises on any subsequent bumps. Pulled over and noticed the sills were sitting on the rockslider arms, look under and see that 3 of the 4 body mounts have pushed up into the body shell and are falling apart. Great
Nearside rear:
front nearside:
front offside:
So thats going to be loads of fun to sort out. Not even sure how to get at them. Might need to chop the mount off the chassis to get in there, or chop the floor out from above maybe?
11 Sep 2021 15:12 #238473 by Lambert
That sucks. Might it be worth splitting the body and chassis?
  • Dirtbird
11 Sep 2021 19:01 - 11 Sep 2021 21:07 #238481 by Dirtbird
Riccy agree with Lambert and a guy did a super write up about making new mounts www.bigjimny.com/index.php/forum/8-my-ji...rtle?start=24#132601
Green Turtle did a super job. Will it ever end mate? Anyway, I'm sure your going to do a good write-up and fix it .
Last edit: 11 Sep 2021 21:07 by Dirtbird.
