Ola`s jimny project
13 Feb 2019 18:57 #203139 by Riccy
B) the best seats for a jimny.
You have done well with the back seats as well!
13 Feb 2019 19:03 #203143 by Lambert
Recaros are the future!
  • MadsV
13 Feb 2019 19:18 #203147 by MadsV
Looks good! Do they slide okey? Did you measure the bar?
  • OlaGB
13 Feb 2019 19:28 #203151 by OlaGB
MadsV wrote: Looks good! Do they slide okey? Did you measure the bar?
They slide OK, but not perfect. Good enough!
I extended the bar approx 23mm..
15 Feb 2019 21:54 #203298 by kirkynut
Can you please tell me - is your transfer box mounted with the original mounts or the straight through bolt with nylon bushes type of heavy duty mount?
Cheers
  • OlaGB
15 Feb 2019 23:24 #203306 by OlaGB
kirkynut wrote: Can you please tell me - is your transfer box mounted with the original mounts or the straight through bolt with nylon bushes type of heavy duty mount?
Cheers
Well, the regeared transfer is a bit noisy (not extreme, but enough), allthough getting better every week. Protection plate underneeth didnt help either...
At first i mounted it with the straight through HD mounts , using the jimnybits metal brackets/mounts.. Way to noisy for me for daily driving. So i bought a new set stock mounts that ive been running for some months now, still using the metal JB mpunts.. Still not quiet, but a hellofalot better than HD.
Ive got noise reduction mats almost on the entire floor, which helps alot for road noise, but gear whine goes straight pass it.
Time to create page: 0.222 seconds
