Engine not starting (G13BB)
30 May 2025 20:03 #260663 by enforcer69@gmail.com
I put the connector from cylinder 1 to cylinder 2, then to cylinder 3 and both injectors are working connected this way.
With test led it shows normal operation to cylinder 1 and 4 and random signal, once or twice then nothing, on cylinders 2 and 3.
Both crankshaft and cameashaft are aligned with marks.
30 May 2025 20:17 #260664 by Lambert
Replied by Lambert on topic Engine not starting
I'm going to agree with what others have said about checking the wiring for having been crushed or shorted or some other how damaged.
30 May 2025 20:34 #260665 by enforcer69@gmail.com
Yes, it seems to be a signal problem on those two injectors, can be anything from damaged wires to bad contact or damaged ECU...
Is very annoying, I was disconnecting and reconnecting everything with battery disconnected and carefully handled, yet something happened...
31 May 2025 14:30 #260667 by enforcer69@gmail.com
Wiring is fine for all 4 injectors
ECU is not giving signal for injectors 2 and 3.
What can cause this? Is very unlikely to get 2 transistors dying simultaneously...
31 May 2025 15:15 #260668 by fordem
Replied by fordem on topic Engine not starting
Have you checked for codes?
31 May 2025 16:11 #260672 by enforcer69@gmail.com
Yes, no errors
Time to create page: 0.110 seconds
