Engine not starting (G13BB)
05 Jun 2025 23:41 #260767
by fordem
Not to me - but only you know what really went on.
If I were to take this entire discussion at face value, there is no mention of any "trauma" to the lower end of the engine, so that suggests it was most likely running with that cracked timing pulley for some time, so whilst the pulley is A problem, I'm questioning if it is THE problem.
One of the things that I'm curious about is you stated that there were no failure codes generated when the cam position sensor was disconnected - why did you not get a P0340?
Replied by fordem on topic Engine not starting (G13BB)
Is pretty obvious, isn't it?
06 Jun 2025 00:27 #260768
by Ovidium
Replied by Ovidium on topic Engine not starting (G13BB)
At the lower part I replaced the oil seal, so I had to remove the sprocket.
Is possible it has an older crack that got worse during this operation, or I handled it poorly, I really can't say.
But the crack was there at first attempt to start the engine.
As the error code for CMP, someone told me is issued only after engine starts, but I cannot confirm or dismiss this info.
Either way, a crack that big there mean 100% a bad signal fed to ECU.
23 Jun 2025 23:53 - 24 Jun 2025 04:41 #260990
by Ovidium
To conclude this topic: I replaced the sprocket and the engine started right away.
Last edit: 24 Jun 2025 04:41 by Ovidium.
Time to create page: 0.095 seconds
