THE DEATH WOBBLE THREAD
  • rut
11 Dec 2013 23:09 #95524 by rut
Replied by rut on topic THE DEATH WOBBLE THREAD
i had the wobble on the mrs jimny checked all the norm with no joy,
in the end i found the rear slider on the front brake caliper on both sides were sized after freeing them up the wobble has gone,
might be worth adding
cheers
The topic has been locked.
13 Dec 2013 04:24 #95700 by Lambert
Replied by Lambert on topic THE DEATH WOBBLE THREAD
Ok I'll add another one. New pads may have to be filed a little on the contact points to the carrier as they can stick on even when the rest of the caliper is free to move.
26 Dec 2013 10:07 #97541 by funkyjimny
Replied by funkyjimny on topic THE DEATH WOBBLE THREAD
I'll add yet another cause.... My Jimmy's only done 36k from new but has had a hard life laning. Where the panhard rod bolts go the chassis the holes have gone oval, I've had to weld some washers on either side.
I've also had it the other end on the axle where the threads stripped from the captive nut, needing a new axle.
I have Rob Storr panhards with rose joint one end and poly the other.
Gary
  • C-U-JIMNY
02 Jan 2014 13:12 #98689 by C-U-JIMNY
Replied by C-U-JIMNY on topic THE DEATH WOBBLE THREAD
Had a similar but very mild shake problem though all the bearings and pins seemed ok, had the wheels balanced, after reading and earlier post about cleaning the alloy wheels and hub contact, done this and applied a bit of copper grease, took all the old balance weights off as they seemed to be lots opposing each other and the problem almost disappeared, keep an eye on the tyre pressures (normal tyres), seems ok and acceptable for now but will see how we get on through time.
great tips
  • Will145
03 Feb 2014 11:36 #103166 by Will145
Replied by Will145 on topic THE DEATH WOBBLE THREAD
What would likely cause intermittent wobble? Sometimes it's smooth as silk between 45-50 but other times I have a mild wobble?
  • Shep
03 Feb 2014 12:38 #103169 by Shep
Time to create page: 0.320 seconds
