DOES everything look ok here ?
jimnyturbo wrote: WOW they look superb m8
+1
Mine look like yours jt. :blush:
So what does a "leak" look like and what's to be done about it?
- JerseyJimny
As you can see I need to sort mine out lol
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk 2
JerseyJimny wrote: Like this
could be a indicator of wheel bearing or king pin bearing trouble
Oh dear - I think I have one that looks like that.
There is a cv joint inside packed with grease.
What happens is the swivel bearings (kingpin bearings) rust and wear. They do this if you go through water, as the big dust seal only seals dust not water, so the swivels get water in, that lies in the lower bearing and makes it rusty.
Once the swivel bearing has worn, the hub moves and allows the front halfshaft to press on the oilseal at the end of the axle tube, and oil gets out of the differential into the swivel housing, and runs out (because the dust seal only seals dust :whistle: )
The cure is to rebuild the swivel bearings, whilst you have the hub off, you can clean the rust off the swivel housings (I used a flapwheel in the drill) and paint them, you need an enamel type paint that dries hard. This provides a nice smooth surface for the big dust seal.
Swivel bearings are fairly cheap in the shop (you don't need kingpins, the old ones are likely fine)
The big dust seals are about £20 each, only change if they are damaged. The axle end seal comes with the kit and is only a couple of pounds. Pack bearings with waterproof grease.
Once fixed, never ever ever ever go through water, drive round it or look for a bridge
facade wrote: The swivel housings on the jimny are supposed to be dry/empty
That is very informative - thanks. It is a job I have never done.
So would I notice the diff oil level drop??
- Smoggy
You could remove the plug and refill to the plug shoulder, counting how much you put in I suppose. If you leave it too long you may lose enough oil to damage the diff if its really worn.
