DOES everything look ok here ?
  • jimnyturbo
19 Jun 2013 18:37 - 20 Jun 2013 06:13 #74431 by jimnyturbo
DOES everything look ok here ? was created by jimnyturbo
a friend of mine said he had a land rover and the ball joint was lovely n shiny, but on nearly every jimny i have seen they look like mine..
it just went through the MOT, SO IT MUST OK, AM I RIGHT ?
i have sprayed it underneath with, clear under seal so that is what the shine is :)
[img
Last edit: 20 Jun 2013 06:13 by jimnyturbo.
  • Vacneb
19 Jun 2013 19:17 #74435 by Vacneb
Replied by Vacneb on topic DOES EVERYTHING LOOK OK HERE ?
I had the same concern so asked the chap at KAP suzuki - apparently they are supposed to be mat black on the Jim. The Lamerover ones are chromed (you have to get some bling on them right?!?!)
  • jimnyturbo
19 Jun 2013 19:39 #74436 by jimnyturbo
Replied by jimnyturbo on topic DOES EVERYTHING LOOK OK HERE ?
cheers Vacneb, glad its not just me that noticed it...
are there any gaitors to stick over, just to protect and hide :unsure:
  • Vacneb
19 Jun 2013 19:50 #74438 by Vacneb
I would say they are better off visible - then any oil leaks wont go un-noticed!
20 Jun 2013 17:58 #74499 by facade
The swivel housings on a Landrover are full of oil, and replaceable. The big seal keeps the oil in, and works against the lovely smooth chromed surface
On a Jimny they are usually full of rusty water, as the big seal is only a dust seal :ohmy: and the housings cannot be replaced. They were simply painted with the same high quality paint suzuki used for the rest of the underneath, hence they are now as rusty as old iron.
I cleaned and painted mine last time I did the swivel bearings, with smoothrite, took a week to dry mind......
The following user(s) said Thank You: jimnyturbo
  • jimnyturbo
20 Jun 2013 19:20 #74514 by jimnyturbo
Replied by jimnyturbo on topic DOES everything look ok here ?
WOW they look superb m8
Time to create page: 0.104 seconds
