DOES everything look ok here ?
- Yellostreak
19 Jul 2013 23:12 #77603
by Yellostreak
Replied by Yellostreak on topic DOES everything look ok here ?
landrovers of old used to have a gaiter that went around the swivel.. caused more problems than it solved as it used to trap moisture and condensation..
not done kingpins on s a jimny before but I'm sure I will be soon!.. when I do I will see if there is scope for a drain hole!
19 Jul 2013 23:16 #77604
I'd have thought a drain hole would get blocked by grease or even let water in??
I had an old landy in the 80s and I think it looked much like this set up except the seal to the barfield housing was more of a seal running on a smooth surface.
Replied by helijohn on topic DOES everything look ok here ?
Yellostreak wrote: when I do I will see if there is scope for a drain hole!
- Yellostreak
23 Jul 2013 16:52 #77999
by Yellostreak
if it lets water in then by virtue it will let it out
- Yellostreak
23 Jul 2013 16:54 #78001
by Yellostreak
well as if by magic... off side seal is oozing goo and oil.. time to test the theory.. will take a photo if I manage it.. of course only time will truly tell if it works! :ohmy:
- markyp2000
23 Jul 2013 17:05 #78003
by markyp2000
It wont let water out due to where it goes in isnt the lowest point on the hub so the water just sits in the bearing and washed the grease out
Replied by markyp2000 on topic DOES everything look ok here ?
Yellostreak wrote: if it lets water in then by virtue it will let it out
23 Jul 2013 19:12 #78014
That sounds awful.
What did I do today on the way to and coming back from the MoT. I am so embarrassed I don't want to say. The vans, truck and cars must have been pissing themselves with laughter.
I was driving around the floods. Never in my life have I done that even in a road car. :blush: :blush:
That sounds awful.
Time to create page: 0.111 seconds
