DOES everything look ok here ?
  • helijohn
22 Jun 2013 11:59 #74654 by helijohn
Replied by helijohn on topic DOES everything look ok here ?
Smoggy wrote: You probs wouldn't notice it drop as there is no visible level indication. Most people just fill them upto the bottom lip of the fill plug (which is about right).
You could remove the plug and refill to the plug shoulder, counting how much you put in I suppose. If you leave it too long you may lose enough oil to damage the diff if its really worn.
I have a dipstick I made aeons ago just for diffs. ;)
  • helijohn
06 Jul 2013 17:24 #76297 by helijohn
facade wrote: The swivel housings on the jimny are supposed to be dry/empty
There is a cv joint inside packed with grease.
What happens is the swivel bearings (kingpin bearings) rust and wear. They do this if you go through water, as the big dust seal only seals dust not water, so the swivels get water in, that lies in the lower bearing and makes it rusty.
Once the swivel bearing has worn, the hub moves and allows the front halfshaft to press on the oilseal at the end of the axle tube, and oil gets out of the differential into the swivel housing, and runs out (because the dust seal only seals dust :whistle: )
The cure is to rebuild the swivel bearings, whilst you have the hub off, you can clean the rust off the swivel housings (I used a flapwheel in the drill) and paint them, you need an enamel type paint that dries hard. This provides a nice smooth surface for the big dust seal.
Swivel bearings are fairly cheap in the shop (you don't need kingpins, the old ones are likely fine)
The big dust seals are about £20 each, only change if they are damaged. The axle end seal comes with the kit and is only a couple of pounds. Pack bearings with waterproof grease.
Once fixed, never ever ever ever go through water, drive round it or look for a bridge B)
One is starting to leak well now. Is there a blow by blow account of what you do to replace the swivel bearings that you know of please?
  • JerseyJimny
06 Jul 2013 17:33 #76298 by JerseyJimny
Replied by JerseyJimny on topic DOES everything look ok here ?
There is a how to on here to replace the kingpin bearings
  • helijohn
06 Jul 2013 17:35 #76299 by helijohn
JerseyJimny wrote: There is a how to on here to replace the kingpin bearings
Yes, thanks. Did a bit of looking and found this.
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
  • PascalASR
07 Jul 2013 03:38 #76312 by PascalASR
Replied by PascalASR on topic DOES everything look ok here ?
UH OH OUCH!!
Dont "never ever ever ever go into the water"? Not an option! Deeper the better! ^_^ Jimny is ALL about impossible mission! I did buy Jimny for exactly this purpose. (Otherwise would buy defender or EVO3) We rather need better solutions instead of "go around water". What i meant is this....... :
v.youku.com/v_show/id_XMTU0NjQ1MDY0.html
and this.....:
v.youku.com/v_show/id_XNTY4NzA1ODA=.html
Cmon guys! We must come out with solution for the problem (If there is any) Soon will take mine for "swimming" and will make you report. Hopefully he swims well! hehehe
  • helijohn
07 Jul 2013 09:18 #76316 by helijohn
PascalASR wrote: UH OH OUCH!!Dont "never ever ever ever go into the water"? Not an option!
The nearest I will get to deep water is snow! :laugh: :laugh: Even thought I do cross fields I avoid mud plugging at all times.....filthy stuff. ;)
Time to create page: 0.098 seconds
