DOES everything look ok here ?
- PascalASR
Uncle Pascal
facade wrote: Once fixed, never ever ever ever go through water, drive round it or look for a bridge
It is really concerning. I have a picture in my head of the lower king pin bearing which is quite visible with the dust seal thingy - swivel seal - removed. So any water reaching up to that height which is about half an inch above the bottom of the front axle tube is going to simply flood in through the seal. Same goes for any deep snow or splashing from potholes. You can pack it with as much grease, waterproof or otherwise, as you like, I don't like immersing bearings in water. So like you I am now thinking keep it in the dry which, unless we are in Iraq, is just not on for a 4X4.
Skoda Yeti, here I come.
- Yellostreak
If the issue is that water gets trapped in there why don't you just drill a hole to let the water out?
packing the bearings with prop shaft grease from a boat shop might help also..
- markyp2000
markyp2000 wrote: The only true way is to get some one that can make a rubber boot that clips to the axle and then takes place of the dust seal and bolts on that way behind the hub
Basically a regular style rubber gaiter for regular CV joints.
I think the mudpluggers use a heavy duty waterproof grease.the seal is only for dust then of course if you go wading water will get in and start to kill off the lower swivel bearing.... If the issue is that water gets trapped in there why don't you just drill a hole to let the water out? .......... packing the bearings with prop shaft grease from a boat shop might help also..
Unavoidable and totally stupid design. I felt OK wading in the Vitara but not this.
PascalASR wrote: UH OH OUCH!!
Dont "never ever ever ever go into the water"? Not an option! Deeper the better!Jimny is ALL about impossible mission! I did buy Jimny for exactly this purpose.
We must come out with solution for the problem (If there is any)
I agree.
