4WD Light Flashing?
30 Nov 2012 21:44 #54532
by j999pre
Grey pick up Jimny
Replied by j999pre on topic 4WD Light Flashing?
No probs
Grey pick up Jimny
- J-Bro
02 Dec 2012 15:20 #54648
by J-Bro
Replied by J-Bro on topic 4WD Light Flashing?
I'm new to 4WD
But I ve used it a few times now. I drives fine. All works as it should.
The other day I put it in and the light started flashing.
My wheels were full lock to the left.
I straightend it up and tryed it again and it stopped flashing.
I guess wheels have to be straight on for it to engage properly?
- SteBurns
02 Dec 2012 15:33 #54650
by SteBurns
Replied by SteBurns on topic 4WD Light Flashing?
As we've confirmed that my 4WD isn't working is there a simple way I can lock it in 4WD for the winter? If so is it still possible to purchase manual locking hubs at a later date so that I can put it back in 2WD again for the summer?
J-Bro - As my 4WD doesn't seem to have worked for a while I've no idea! I'm sure your question will be answered shortly...
02 Dec 2012 16:14 - 02 Dec 2012 16:16 #54652
by j999pre
Grey pick up Jimny
Take your hubs off and manually lock them. Finger in the middle and pull out to engage into splines. Put them back on.
Now connect both spigots together on the back of the each complete axle hub assembly. Stops water getting in.you can use one of the rubber pipes that are there already. Also this way whatever your vacuum system does will have no effect on the hubs. Bingo done. If you want the light to stop flashing too connect the two wires on the vacuum sensor together. This its below the two vacuum valves.
Grey pick up Jimny
Last edit: 02 Dec 2012 16:16 by j999pre.
The following user(s) said Thank You: SteBurns
- SteBurns
07 Dec 2012 20:31 #55108
by SteBurns
Did it this afternoon, it really is a 15min job isn't it! 4wd is working fine now
- Tadpole
07 Dec 2012 21:07 #55115
by Tadpole
Replied by Tadpole on topic 4WD Light Flashing?
Pleased it's worked out for you, one less thing on the 'To Do List' ............. :whistle:SteBurns wrote: Did it this afternoon, it really is a 15min job isn't it! 4wd is working fine now
Time to create page: 0.130 seconds
