4WD Light Flashing?
  • SteBurns
24 Nov 2012 13:35 #54093 by SteBurns
4WD Light Flashing? was created by SteBurns
My Jimny never goes off-road so I never use the 4WD, but yesterday I drove down some muddy lanes so I dropped it into 4WD mode. The 4WD appeared to be working, but the light on the dash was flashing.
Is this normal? I don't have a manual so I can't check... What could I look for? What could it be?
Thanks.
  • captain jimny
24 Nov 2012 15:10 #54096 by captain jimny
Replied by captain jimny on topic 4WD Light Flashing?
You could try stopping and reversing slowly. Go backwards and forwards a couple of times that usually does the trick.
24 Nov 2012 16:52 #54099 by facade
Replied by facade on topic 4WD Light Flashing?
You have a vacuum leak, and the front hubs are not working, so likely the 4wd doesn't work.
Easiest thing to check: pop the bonnet, and look for a rubber pipe about 8mm diameter leading from the inlet manifold to a birds nest of rubber pipes under the battery. If this is split or disconnected the light flashes.
If it is intact, you need to look at all the rubber and metal pipes underneath, from the hubs all the way back to that birds nest under the battery.
The following user(s) said Thank You: SteBurns
  • SteBurns
25 Nov 2012 14:11 - 25 Nov 2012 14:13 #54134 by SteBurns
Replied by SteBurns on topic 4WD Light Flashing?
It would appear that the 4WD isn't working, I've tried going forwards and backwards but it had no effect. I've had a look under the bonnet, but I was distracted by a pipe that didn't go anywhere, and a lead that was also dangling free. My technical knowledge is pretty low, so I took pictures to illustrate...
[img
Untitled by SteBurns , on Flickr
[img
Last edit: 25 Nov 2012 14:13 by SteBurns.
25 Nov 2012 14:26 - 25 Nov 2012 14:28 #54135 by j999pre
Replied by j999pre on topic 4WD Light Flashing?
The lead with the sensor on plugs in the side of the air box to read air intake temperature.
The pipe is just a vent for the emissions charcoal cannister.
Grey pick up Jimny
Last edit: 25 Nov 2012 14:28 by j999pre.
  • SteBurns
25 Nov 2012 14:36 #54136 by SteBurns
That would make sense as the previous owner fitted an aftermarket air filter, thanks.
Are there any good Midlands-based Jimny specialists that people could recommend? I'd rather not take it to Suzuki!
Time to create page: 0.168 seconds
