Remote central locking
- bigoffroader
29 Mar 2012 05:52 - 29 Mar 2012 05:55 #36556
by bigoffroader
Replied by bigoffroader on topic Re: Remote central locking
Followed the instructions but cant get it to work
Where do I find the blue/red wire? to lock the doors
I know the remote locking box is working
I've wired it up works fine to unlock using the brown/yellow wire but can't find a wire to lock the door?
Anyone got any ideas?
Sorry mine is an X reg 2000 with the newer engine in
Last edit: 29 Mar 2012 05:55 by bigoffroader.
- bigoffroader
02 Apr 2012 15:59 - 02 Apr 2012 16:00 #36780
by bigoffroader
Yes I've finally got the doors to unlock AND LOCK If you don't have the blue/red wire
I will post the info better when I'm not on my phone but basically connect the unlock wire to the brown/yellow wire and the lock wire is a little more involved
You have to take the drivers door panel off so you can get to the wires in the door.
The black and White dot wire that goes to the central locking mechanism on the door is also connected to the earth wire for the electric windows, you have to undo the joint and run a new earth wire to the central locking so it has it's own ear. So it goes earth to central locking control box and the output line from it to the black/while dot on the central locking on the driver door.
Don't forget to disconnect the black/whit dot wire from the black wire in the door otherwise it will work but then the electric windows hit their limit switch on open the doors will lock, but at least the window will be open to unlock the car
j999pre wrote: No luck as yet. Anyone?
Last edit: 02 Apr 2012 16:00 by bigoffroader.
- Goat
15 Apr 2012 08:37 #37608
by Goat
Replied by Goat on topic Re: Remote central locking
Got it to work on my 01 jimny. Wires were as described. Had to use choc blocks though as those snap on wire connectors proved rubbish.
- Goat
15 Apr 2012 08:46 #37610
by Goat
Is it possible to get the light to come on? On the jimny with keyless entry the light comes on. Just thought the non keyless entry model might just not have the right key but the stuff in the car might be the same?
15 Apr 2012 14:30 #37631
by j999pre
I've split the join on the black wire with white dots in the drivers door and connected it to the switching earth on the new central locking box. It now unlocks but locks straight away again. Before I did this the unlock was working fine. I take it I've missed something? Does yours still central lock on the key too?
Grey pick up Jimny
Replied by j999pre on topic Re: Remote central locking
Grey pick up Jimny
15 Apr 2012 16:50 #37642
by j999pre
Grey pick up Jimny
Its officially drove me mad!!!!
Who needs remote locking anyway! :lol:
I'll have another bash at it tomorrow. :evil:
Grey pick up Jimny
Time to create page: 0.178 seconds
