Remote central locking
- happypig
21 Nov 2011 16:41 #26239
by happypig
Remote central locking was created by happypig
I bought a cheapo kit off eBay. Don't need/want it to flash lights or work horn, just lock and unlock the doors.
Got round to connecting it today and with the aid of the wiring diagram I have worked out that it sticks an earth on the blue/red wire to lock it and the brown/yellow wire to unlock.
Plugged the controller in and when I press the button, I can hear a relay activating but the locks don't activate.
I ran out of light and dinner break then and have had to leave it but before I go back Wednesday I wondered if anyone has fitted one and had the same issues ?
- v8dougie
21 Nov 2011 19:40 #26254
by v8dougie
Replied by v8dougie on topic Re: Remote central locking
Hi I fitted a full alarm kit off ebay onto the vehicle, all went well apart from the remote central locking system. It took me ages to work out the wiring arrangement I required, was a mixture of those given on the instructions. For a start I could either get the doors to lock, or by changing the wiring it would unlock, but it would not do both.
Eventually by fiddling with the wires on the alarm system I got it to work okay. The wires I had picked in the car were correct, so knew it was my device. The way I decided the wires on the vehicle was to utilize a direct battery feed, simulating the trigger from the lock, thus I could work out polarity etc. It took me ages! I cannot remember the wires, might be able to have a look if you get nowhere, but busy this week so no promises!
HTH
HTH
- p1ngu32
21 Nov 2011 20:29 #26257
by p1ngu32
Replied by p1ngu32 on topic Re: Remote central locking
it could be because the jimny is negative switched. what i did with mine to make things easy was to wire it up to a 2 wire central locking solenoid and attached that to the drivers door pin, when the solenoid opertates it kicks in the jimnys central locking to lock the rest of the doors.
21 Nov 2011 21:26 #26263
by Halford
Replied by Halford on topic Re: Remote central locking
ditto - thats how mine is sorted
- r_ogilvy
22 Nov 2011 06:54 #26266
by r_ogilvy
Replied by r_ogilvy on topic Re: Remote central locking
I bought a falcon alarm a while back, I remember fitting to relays one for lock and one for unlock, oin the the manual it explained there is different types of locking on cars, positive locking and negative locking, I was picking out the positive and I needed the negative wires,
I don't no if this helps.
If u can here the relay clicking try connecting a horn or light on the wires from your alarm witch should go on the locking system and see if the horn sounds. Then u can tell if the alarm is working, but there is positive and negative locking so check that if so I thing is a case of swapping the wires on the relay. That's what my instructions explained
- happypig
22 Nov 2011 11:30 #26278
by happypig
Replied by happypig on topic Re: Remote central locking
Thanks for the inputs. I'll get a meter on it when I get time and have a proper play. I'm quite at home with wiring diagrams and testing so it shouldn't be too hard to figure out, it's just a pain getting the connector in/out of the module so I might try and take the module off so I can play with it all connected up.
I'll post a write up/photos when I've figured it.
Time to create page: 0.169 seconds
