Engine light on not starting
- Wayne 35353535
- Junior Member
18 Jul 2025 16:09 #261253
by Wayne 35353535
Replied by Wayne 35353535 on topic Engine light on not starting
Hi ,I think you may have sorted this problem out, I took the cam sensor out to find it is broken at the bottom, were a connector should fit, I'll send for a new one and let you know, I'm sure this is it.
- Wayne 35353535
- Junior Member
22 Jul 2025 17:19 #261282
by Wayne 35353535
Fitted the new cam sensor and bingo, all go's well, it took a bit of time to get the fuel through. Running fine now, I must have to thank you a million times, I would probably never looked for the problem there. Thanks once more. , wayne.
22 Jul 2025 18:08 #261283
by fordem
Replied by fordem on topic Engine light on not starting
You're welcome, and you're the person who identified the problem as that loose connector, I only helped you find where it belonged.
- Wayne 35353535
- Junior Member
23 Jul 2025 14:44 #261286
by Wayne 35353535
Ok, the engine now runs fine, but with a very high idle speed, I think the throttle body adjuster could be stuck, I'll take off tomorrow and look,but all else good.
24 Jul 2025 00:47 #261287
by fordem
Check for vacuum leaks, possible hoses not reconnected, maybe for the front hub vacuum systems - that's an area I have no experience with, I just know they are vacuum operated.
- Wayne 35353535
- Junior Member
24 Jul 2025 14:02 #261290
by Wayne 35353535
Thanks, so when I tap the throttle body when engine running it readjusts the idle speed I think it's freeing off, seems to be ok now. Thanks again.
Time to create page: 0.259 seconds
