Engine light on not starting
- Wayne 35353535
- Junior Member
06 Jul 2025 13:42 #261137
by Wayne 35353535
Engine light on not starting was created by Wayne 35353535
Hi after a body off restoration my car engine light is on and not going off and turns but won't start. Getting fuel to engine. Running fine before restoration. Any ideas.
- Thank you received: 2005
06 Jul 2025 16:25 #261138
Replied by Lambert on topic Engine light on not starting
The first thing is to get the codes off the eml. Then check that everything is plugged in and nothing is trapped wiring loom wise.
- Wayne 35353535
- Junior Member
07 Jul 2025 14:07 #261143
by Wayne 35353535
Replied by Wayne 35353535 on topic Engine light on not starting
Thanks but I am not sure how to get code from eml . Everything else looks fine .
07 Jul 2025 16:13 #261145
Depends on what year jimny you have, very early ones you bridge pins and read flashes on the dash light on later ones with obd11 a simple reader will set you back maybe 20 quid.
07 Jul 2025 18:12 #261146
by fordem
Replied by fordem on topic Engine light on not starting
It might be a good idea to provide a little more detail about the Jimny itself, what year is it (Jimnys have been around for many, many years), what engine does it have?
- Wayne 35353535
- Junior Member
09 Jul 2025 09:00 #261162
by Wayne 35353535
Hi I have tried a reader obd11 but won't load up at the end giving only ERROR read out. The year of jimny is 2001 W reg.
Time to create page: 0.219 seconds
