Engine light on not starting
06 Jul 2025 13:42 #261137 by Wayne 35353535
Hi after  a body  off restoration  my car engine  light  is on and not going off and turns  but won't  start. Getting  fuel  to engine. Running  fine  before  restoration. Any ideas.
06 Jul 2025 16:25 #261138 by Lambert
The first thing is to get the codes off the eml. Then check that everything is plugged in and nothing is trapped wiring loom wise.
07 Jul 2025 14:07 #261143 by Wayne 35353535
Thanks but I am not sure how to get code from eml . Everything else looks fine .
07 Jul 2025 16:13 #261145 by Lambert
Depends on what year jimny you have, very early ones you bridge pins and read flashes on the dash light on later ones with obd11 a simple reader will set you back maybe 20 quid.
07 Jul 2025 18:12 #261146 by fordem
Replied by fordem on topic Engine light on not starting
It might be a good idea to provide a little more detail about the Jimny itself, what year is it (Jimnys have been around for many, many years), what engine does it have?
09 Jul 2025 09:00 #261162 by Wayne 35353535
Hi I have tried a reader obd11 but won't load up at the end giving only ERROR read out. The year of jimny is 2001 W reg.
Time to create page: 0.220 seconds
