Engine light on not starting
16 Jul 2025 01:17 #261235 by fordem
Replied by fordem on topic Engine light on not starting
You say you're getting a Code 12, that would suggest there is either no immobilizer fitted, or no immobilizer fault detected, an immobilizer fault would show an 8x code - 81, 82, 83 or 84.
Have you checked for ignition power to the coils? Each coil connector has three wires, black with blue stripe is the ground, black with white stripe is +12V, you should have power with the ignition switched on.
16 Jul 2025 14:30 #261238 by Wayne 35353535
Ok so I have checked the coil intake wires, 12v reading ok on both coils,with ignition on,so I should be getting a spark ,shouldn't I, I'll have another go for spark check.
17 Jul 2025 13:25 #261244 by Wayne 35353535
Ok so tried a spark check, there is no spark at all,nothing coming from coils, I tried a check on the input to coil with engine turnover and still 12v,I tried a output from coil with engine turnover and nothing coming out?
17 Jul 2025 13:41 #261245 by fordem
Do me a favor and walk me through, step-by-step how you're doing these checks.
17 Jul 2025 13:42 #261246 by Wayne 35353535
Should there be a reading from the brown /black wire from the coil supply plug.
17 Jul 2025 13:47 #261247 by fordem
Have a look at this video - focus on the 0.34~0.45 portion - find that sensor on your car and make sure it's connected.
Time to create page: 0.968 seconds
