Body lift Jimmy 04 1.3 help
30 Aug 2020 20:15 #227572 by jackonlyjack
Ideally you need 3" lift
You could have 2" lift if you're willing to trim arches and bumpers
Do you have wheel spacers or - off set wheels ?
01 Sep 2020 09:03 - 01 Sep 2020 09:06 #227620 by Scot The Sniper
Hi Jack thanks for your reply as in my original post when I noticed a broken spring this is where it all went wrong I bought 3" front springs as I thought it was raised 3" but it was the body it was raised 3" so took body lift of rifhtened it back down to normal size then got springs and shocks for rear and shocks dor front 3" shocks so fitted all the springs and shocks took for a drive pulling severly right now im told i need to get adjustable panhard rod and steering rod to correct this and now body is back down tyres are hitting arches.
P.s it does have wheel spacers and another think I bought it with the body lift
Last edit: 01 Sep 2020 09:06 by Scot The Sniper. Reason: Adding to discription
01 Sep 2020 15:33 #227628 by jackonlyjack
So now you have a complete 3" spring and shock lift
You need adjustable panhard rods front and rear
Cheapest you can get are from Richard Fox
When fitted measure from the tyre or wheel rim inside edge to chassis rail
Use this method to get your wheels sitting level with car body
This may stop your rubbing issues
Maybe will need to get tracking done at this point
02 Sep 2020 14:22 #227646 by Scot The Sniper
Thanks for this Jack will do this and post when done will I need adjustable steering rod as well
02 Sep 2020 14:43 #227649 by jackonlyjack
04 Sep 2020 12:53 #227713 by Scot The Sniper
Thanks very much jack
Time to create page: 0.225 seconds
