Body lift Jimmy 04 1.3 help
26 Aug 2020 14:00 #227368
by 300bhpton
Replied by 300bhpton on topic Body lift Jimmy 04 1.3 help
Hope I don't come across as mean or grumpy.
But I assume you are modding purely for looks and not for off or on road performance?
If it is the later. You'd do yourself a world of favours by reading up, learning and understanding how the suspension works. And more importantly why it works that way.
Simply bolting crap on and hoping for the best while not having a clue to how any of it actually works, is a sure fired way of ending up with a heap. And there are so many badly modified 4x4's out there already, there really is no need for more of them.
Putting in the up front effort and learning how it all works, should pay dividends, as you'll know exactly what you need to do and why.
26 Aug 2020 14:37 #227371
Replied by jackonlyjack on topic Body lift Jimmy 04 1.3 help
Put 4x spring spacers back in to lift higher
DO not touch drive shafts this is not effected by any amount of lift
Front propshaft could benefit from a one inch spacer with a 4+ inch lift
- X8GGY
27 Aug 2020 19:16 #227417
That's an old trick on the Vitara, not applicable to the Jimny
Replied by X8GGY on topic Body lift Jimmy 04 1.3 help
Scot The Sniper wrote: ... Also with the suspension lifted will I have to take the circlip of the driveshafts at the front to give it the extra movement.
- Scot The Sniper
- Senior Member
- Thank you received: 4
28 Aug 2020 13:49 #227461
by Scot The Sniper
Replied by Scot The Sniper on topic Body lift Jimmy 04 1.3 help
Hi mate I know what your saying and I totally agree only thing is I was only replacing the clutch and noticed a broken spring with it having a 3" lift I thought it was 3" springs already in there i did not know it was a body lift so all this is because of the broken spring. If I had known it was original springs it it i would of just put them in and left it as it was bit was on Facebook group and they advised to just get 3" springs for the rear and its just caused so many problems with me not having the knowledge to do this Iam a mechanic and have access to a ramp and my tools I can do the jobs easily but as you say if I knew I would not be pulling my hair out and of course I need to start somewhere and yes its just for looks and off road vermin control no proper offloading. So any advice is greatly appreciated. Scot
28 Aug 2020 14:22 #227463
So lets have a fresh start
What size tyres are fitted ?
- Scot The Sniper
- Senior Member
30 Aug 2020 12:17 #227546
by Scot The Sniper
Hi mate they are 235 75 15
Time to create page: 0.825 seconds
