Body lift Jimmy 04 1.3 help
30 Jun 2020 19:16 #224305 by Scot The Sniper
Hi Jack I used an air gun with a wire brush on the end and cleaned the splines up then put grease on then used a drill with a finger wire brush and also cleaned up the splines on the one u sent me then greased that also. So should go back on easy enough i hope
  • X8GGY
30 Jun 2020 20:19 #224312 by X8GGY
Replied by X8GGY on topic Body lift Jimmy 04 1.3 help
Coming from "Vitara-land" (before I "upgraded" to a Jimny! ;) ) I've always put the steering shaft back in whilst lowering the body back down... it might work Jack's way, but I prefer to get it in during the body descent... ;)
02 Jul 2020 16:29 #224394 by Scot The Sniper
OK guys thanks very much for the advice I got the steering linkage on i tried it Jack's way first but it was a tad to long to get it back on so lifted the body up slightly and on it popped with no hassle whatsoever bolted all the body back down and no problems there either just need to get the nuts on the top of the new shocks as jack said might need to use an old rubber for this and I have the springs for the rear but to my absolute annoyance rear shocks are out of stock grrrrr
  • X8GGY
02 Jul 2020 19:16 #224408 by X8GGY
Scot The Sniper wrote: OK guys thanks very much for the advice I got the steering linkage on i tried it Jack's way first but it was a tad to long to get it back on so lifted the body up slightly and on it popped with no hassle whatsoever bolted all the body back down and no problems there either just need to get the nuts on the top of the new shocks as jack said might need to use an old rubber for this and I have the springs for the rear but to my absolute annoyance rear shocks are out of stock grrrrr
Sorry. you didn't make that quite clear enough... my way was betterer? ;) :P
03 Jul 2020 00:14 #224421 by Scot The Sniper
lol yes your way was better
25 Jul 2020 02:12 #225601 by Scot The Sniper
Ok back again just got my shocks threw so gonna fit the rear springs and shocks. I have 2 questions
1. On trolling threw the facebook jimny groups i noticed someone doing a 2" lift and asking if he should put the rubber cones back in on top of the lift kit when i took my plastic 1.5 inch lift spacers out of my spring i did not have any rubber cones to put back in will i need these please.
2 will i need to buy castor correction bushes for the front radious arms
Thx in advance
Time to create page: 0.317 seconds
