Body lift Jimmy 04 1.3 help
02 Aug 2020 15:46 #225985 by Lambert
Replied by Lambert on topic Body lift Jimmy 04 1.3 help
Other than the springs and dampers have you fitted things like extended panhard bars and longer brake lines?
02 Aug 2020 15:51 #225986 by Riccy
Replied by Riccy on topic Body lift Jimmy 04 1.3 help
Steering bars are too long or need adjusted (if adjustable) im afraid.
A wheel alignment/tracking at a garage is always needed after altering this sort of stuff. Problem is finding one that will work on a modified car usually :-(
Panhard rods are probably out as well (or have you covered that already?) If adjustable you need to set them so that the axle is central to the chassis. Measure off the chassis to the tyre and get it in the middle before worrying about the steering bars.
If you do take it to a garage for an alignment/tracking the steering 'toe-in' should be set at 2 degrees inwards (for a standard car, maybe less for huge tyres). The only other thing they can adjust is the panhards (if adjustable), but thats more for centering the axle to the car properly, but it does have an affect on the steering position so needs set before the steering bars ;-)
02 Aug 2020 16:26 #225988 by Scot The Sniper
Im losing the will to live with this jimny all cause i noticed a broken spring all it had was a 3" body lift too
So now i need to buy adjustable panhard rods
02 Aug 2020 16:40 #225989 by Roger Fairclough
Sorry about this but 4th picture page 2 appears to show heavily corroded brake pipes in the background.
Roger
02 Aug 2020 16:41 #225990 by Roger Fairclough
Sorry , meant to say 3rd picture.
Roger
02 Aug 2020 17:43 #225991 by Scot The Sniper
Roger Fairclough wrote: Sorry , meant to say 3rd picture.
Roger
Hi roger thx for this info i had spotted these before and on actual fact there the vacuum pipes for the 4x4 and thete in had im gonna use brake pipe to fix them but thanks for the info
Time to create page: 0.193 seconds
