Chinese E-Locker
- Thank you received: 2004
04 Oct 2019 03:58 #214283
Replied by Lambert on topic Chinese E-Locker
From the pictures there doesn't seem to be much of a radius transition between the flange and the body of the diff which is going to cause a significant stress accumulation as axial load increases as a function of the crown and pinion trying to separate under the increased load applied by the oversized tyres. That axial load would cause a failure in the flange which would then be partially obscured as the flange was forced round the body after failure. Not knowing the metallurgy of the steel used its not easy to say it was the inclusion of a stress riser that was ultimately to blame or whether it was a inappropriate material but it would be more normal to have the half shaft fail than the crown flange.
The following user(s) said Thank You: zukebob
- Thank you received: 227
05 Oct 2019 01:33 #214324
by zukebob
Replied by zukebob on topic Chinese E-Locker
You are correct about stress risers when there is an insufficient radius. You are also correct that there would be an axial load on the flange. The axial load would actually be a component of a combined stress condition that could most easily be analyzed through a finite element model. It could be accomplished through hand calculations after a resolution of forces but that is best handled by someone who is very experienced in failure analysis. Again to your point, none of that can be done without knowing material properties.
I sincerely hope that I wasn't being disrespectful to Nikola's friend when I made my comment. From my experience, when a part came to our company, the first thing it (a sampling) would go through is a visual inspection. It was handled by the material engineering department rather than ours but I was familiar with their processes. That visual inspection can tell you a lot. In comparing the pictures that Nikola provided, and comparing them to the locker I installed and the picture of the TRE, I simply would have been very suspicious.
The good thing is that I am now scheduled to be heading up to the mountains in two weeks and can provide some locker feedback, hopefully bringing this thread back on topic.
- Nikola
13 Oct 2019 05:24 #214684
by Nikola
Replied by Nikola on topic Chinese E-Locker
My dear friends and colleagues, i wish to share with you just my experience and knowledge about jimny's... That's why i wrote chinese lockers are not good and proof it with evidence. I didn't said USA or Australian parts guaranteed quality but as per my opinion they are much better... ones i hear: " i am not rich enough to buy cheap things ".
On my car i am trying to put best parts and in past that showed me as good choice. All races i finished without some big issues untill now and i force my car up to limits. If my car with 250hp not have issues with ARB, i think normal user will not have any problem for lifetime....
13 Oct 2019 08:11 #214689
by zukebob
And I for one hope you continue to contribute
- moles
21 Oct 2019 19:57 #215013
by moles
Replied by moles on topic Chinese E-Locker
Any news on this diff Bob?
23 Oct 2019 00:15 - 24 Oct 2019 00:11 #215061
by zukebob
I'm heading into the mountains in 4 days. I will check the locker then but likely only for operation (how it engages while moving forward and temporarily disengages when you reverse) unless I have reasonable opportunity to hit a trail. The main purpose for the trip is to sign papers for title transfer on the property we're buying. We did have some heavy rains yesterday so there may be some mud but it has been unusually dry over the last several weeks. I will sidetrack to a trail if we have time. We'll see.
The only thing I've done so far is trying to see the effects of the LSD. I have tried to make sharp U-turns at as fast a speed as I can (and still be safe). Hit a hard pack area with some loose gravel to see if I could break the rear end loose. All-in-all I'm fairly pleased. It performs well enough but seems to have less effect on handling in normal driving than my previous LSD did (different vehicle).
Although the testing will be somewhat limited, will update after we get back.
Here are a couple of videos that I linked to earlier. They show a Japanese group testing them out.
Last edit: 24 Oct 2019 00:11 by zukebob.
The following user(s) said Thank You: moles
Time to create page: 0.108 seconds
