Chinese E-Locker
01 Oct 2019 06:54 #214094 by zukebob
Replied by zukebob on topic Chinese E-Locker
Now THAT is a failure! Am I seeing it correctly? The ring gear mounting flange actually sheared?
If you can, ask your friend where he sourced the locker. I'm really curious which company produced that. I am also still curious what the operational scenario was. What was he doing at the moment the locker failed?
  • Nikola
01 Oct 2019 16:18 - 02 Oct 2019 04:06 #214115 by Nikola
Replied by Nikola on topic Chinese E-Locker
Yes, you are right. The ring gear mounting flange sheared. That was Air Locker, copy of ARB , but same rubbish like all chinese products... My advice is: Do not buy cheap parts, you will spend more money to repair it....
Last edit: 02 Oct 2019 04:06 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
02 Oct 2019 04:09 #214155 by Lambert
Replied by Lambert on topic Chinese E-Locker
This cannot have happened just driving down a bit of a rough track even with a Chinese locker it has to have been doing something extreme or running huge tyres or something.
  • Nikola
02 Oct 2019 09:38 #214164 by Nikola
This part of air locker should be strongest part... gears, bearings etc... have to be weaker parts... Anyhow quality of chinese locker is poor.
P.s. when you need diff lock ofcourse you are doing something extreme... size of tyres were 31". That is not excuse to have failure like this... ARB quality is completely different story... I recommend just ARB for off road use.
04 Oct 2019 01:18 #214280 by zukebob
Lambert:
As Nikola says, even relatively hard use shouldn’t break a locker like this. That said, I do agree with you that there is more to this story.
Just from looking at the pictures it would be difficult to make a guess of exactly why it failed. I will say that the pictures do show some things that don’t make sense to me. While I was working I had the opportunity to review numerous failed parts and I can say that the shear surface pattern isn’t normal. The uniform cross section of the shear area on the locker body makes me suspicious of the manufacturing techniques used. I also can’t help but question why there appears to be seams on the body of the locker.
Now while all of that does support Nikola’s claim that this Chinese locker was junk, I can buy junk made in the U.S., the UK, the EU and even ARB’s home in Australia. If you buy junk, you own junk. My simplest assessment is that this failed because it WAS junk. I wouldn’t put that on the Chinese manufacturing industry. If I had received that locker, I would never EVER have installed it in my car. I honestly don’t mean any disrespect to Nikola’s friend but I do have to question his judgement in going forward with the install.
04 Oct 2019 01:20 #214281 by zukebob
Nikola:
You are absolutely correct that the locker your friend installed appears, for numerous reasons, to be poorly made.
While I obviously disagree with your general comments about Chinese lockers being universally poor quality, you have the right to that opinion and I won’t even try to change your mind. If for no other reason, I will defer to the old expression that “you shouldn’t try to teach a pig to sing…..it just wastes your time and annoys the pig”. I won’t waste either of our time trying to convince you of something you already have fixed in your mind.
For the sake of others reading this thread I would simply remind them that there are several members on this forum, as well as numerous members on the Australian forum, that have been running Chinese lockers hard and long without issue. As I wrote in another thread, here in the Philippines there is about a 5 to 2 ratio of HF brand (Chinese) to the ARB. I have witnessed a large number of these folks running their vehicles (not just Jimnys) hard and bordering on abuse. I don’t know of even one failure. Lastly, I find it hard to believe that a company like TRE (Chinese) would offer the same 5 year warranty that ARB does while selling a product that fails after several uses.
