  • S200KYS
06 Jan 2017 14:55 #176310 by S200KYS
maverick wrote: Blimey, where do you go to do this much damage???
Following some nutter in a green Jimny? ;)
:P
The topic has been locked.
  • S200KYS
01 Feb 2017 22:24 - 01 Feb 2017 22:33 #177645 by S200KYS
Hmmm, I've not updated this build / ongoing build thread for a while?! I've been quite happy with the blue S200KYS Jimny, and it's been performing well in all "our little groups" greenlaning adventures...
The one little thing that's always plagued most of our Jimnys, on the "Tight & Scratchy" greenlanes we love so much... is Snorkel Heads!
Snorkels were conceived mostly for hot sunny climes where the idea was to keep water out on river crossings, and dust ingress to a minimum while driving in "the outback"
But, that doesn't quite suit our environment of driving Tight & Scratchy 'lanes in the UK where the trees and their branches see the snorkel head as an easy target... Most of us have either replaced the (lost!) snorkel heads with plumbing elbows, or regularly stop to retrieve lost and broken heads, and their grills...
With this in mind, I started looking at my own genuine Safari Snorkel...!
See how the head sits UP and OUT
And FORWARD even....?
So, after a bit of thought and measuring... I drilled a small hole into the Safari Snorkel's rising tube and then stuck a small screwdriver in to work out the internal diameter of the pipe... I'd already bought a Southdown Land Rover snorkel head which I thought would be the right size, and visited my local plumbers' merchants and had a rummage through their black drainpipe fittings...
And then with angle grinder and reciprocating saw in hand, I decided to cut the top third off the Safari Snorkel..! :ohmy:
DISASTER! Although the internal diameter was right, where I'd cut wasn't circular internally! So I had to warm the plumbing elbows up with a heat gun (read blow torch!) and adapt it to fit...
The end result...
LUCKILY! Didn't look too bad (It looks better in real-life rather than the photos!)
A couple of 45o bends and the Southdown Snorkel Head bring it inside of the bodyline of the little Jimny...
And I then also added a protection guard of 1/2" steel bar around it...
Pop-riveted to the snorkel body, the guard will sweep branches up and over the snorkel head...
From above, the U-bend of the steel bar protects the small snorkel head...
Time will tell how it performs... But I'm hoping it will be "fit and forget";... It is now inside of the body-line and in the top corner of the windscreen, out of "Zone-A" and I've already checked with my MOT Tester and he's happy with it...
So it should, hopefully, just brush branches out of the way as we proceed down our beloved "Tight and Scratchy" 'lanes...? ;)
Last edit: 01 Feb 2017 22:33 by S200KYS.
  • Venter
02 Feb 2017 09:31 #177653 by Venter
Replied by Venter on topic Dave's "S200KYS" Jimny 'laner Build...
Very good Dave, excellent idea that.
You should start making kits, you'll be well on your way to your first (second?) million £££!
I like the extra thought re the extra steel protection, many people would have moved the intake head inwards and then said job's a good 'un
  • S200KYS
02 Feb 2017 10:07 #177654 by S200KYS
Thanks Venter B) :blush:
  • Daniel30
02 Feb 2017 12:40 - 02 Feb 2017 12:41 #177655 by Daniel30
Replied by Daniel30 on topic Dave's "S200KYS" Jimny 'laner Build...
Nice mod Dave B) like that snorkel bull bar :)
Last edit: 02 Feb 2017 12:41 by Daniel30.
  • S200KYS
02 Feb 2017 19:22 #177677 by S200KYS
LOL, thanks Dan, I like that! ;)
Dave
Time to create page: 0.258 seconds
