Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
Stabiliser/Drop Link - MOT Time
​So the MOT time is approaching for "LittleJimny" and we knew that one of the stabiliser links (or drop links) is bent and leaking grease. It is a straight forward process to change these although inevitably occasionally things get stuck. Here is the old link in position, all you have to do is undo the two nuts securing it. ​ As they are swiveling ...
  11887 Hits
ARB air line repair
ARB air line repair
​When the rear axle was ripped off its mount it looks as if the air fitting for the ARB locker was damage. The air fitting consists of pipework fitted through what ARB call a bulkhead fitting. This has pulled out of the diff casing. ​The ARB was not fitted by me and I do not have the instructions. However Google shows that this fitting should be in...
  14143 Hits
What the postman brought....
I used to have a rear disc conversion fitted that I really did not get on with. It never seemed to work properly and needed constant attention in order to get any sort of braking capability. This has been delaying my rebuild as I could not be inspired to re-fit it and go through the trials again. However, I have bitten the bullet and bought a new k...
  10445 Hits
Tags:
ColinK's Jimny
ColinK's Jimny
ColinK has sent in some pictures for display in the gallery, thanks Colin
  9700 Hits
Tags:
Spotted on M3 slipping to A34 North
Spotted - I think its Ali?
  9490 Hits
Tags:
