Code P0172 - Engine Running Rich
- ThatRedTruck
08 Aug 2017 01:50 #183237
by ThatRedTruck
Code P0172 - Engine Running Rich was created by ThatRedTruck
Hi guys,
I've been having problems with my 2012 Suzuki Jimny Sierra. It has a standard M13A engine.
Initialy, a check engine light was triggered. Freeze frame data revealed that the engine was at idle when it exceeded threshold for fuel trims. The LTFT was at -14.8 and the STFT was at -20.4.
When at load, the LTFT reduces to between -7.8 and -13.0. The STFT either zeros or becomes lean (around +7).
All four spark plugs are fouled.
My first thought was excessive fuel pressure. I tried my luck at changing the fuel pressure regulator on the assumption that it was stuck closed.
The results were significantly better. The LTFT went down to -7.8 and the STFT zeroed.
But, around a week later the fuel trim returned to running rich.
I'm suspecting clogged fuel injectors, restriction in the return line or an EGR issue. I used opal fuel (low quality 91 octane) for a year. Perhaps that depositied gunk in the injectors.
What do ya's reckon. Any advice would be greatly appreciated.
10 Aug 2017 20:20 #183341
by Rhinoman
Replied by Rhinoman on topic Code P0172 - Engine Running Rich
Check for a cracked exhaust manifold or a leak that would cause a false reading from the O2 sensor.
13 Aug 2017 07:07 #183366
by facade
Replied by facade on topic Code P0172 - Engine Running Rich
If there are no leaks, swap out the oxygen sensor on the manifold, when this goes out of spec it causes over fuelling.
03 Oct 2026 09:03 #265347
by Mikem
Replied by Mikem on topic Code P0172 - Engine Running Rich
Hi, I came across your 2017 thread about P0172 on your Jimny Sierra. My Gen 3 Jimny (M13A VVT) shows almost the same numbers: about −15% long-term and −20% short-term at idle, much closer to normal when driving. I've fitted a new upstream O2 sensor and it hasn't changed. Did you ever find what fixed yours? Injectors, the return line, EGR, or something else? Any pointers much appreciated.
Time to create page: 0.197 seconds
