Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
Axle breathers
As part of the rebuild I decided to fit my own axle breather kit. My Jimny has the old "hosepipe" style which was large, untidy and the hosepipes had hardened off over the years.
  8379 Hits
Tags:
Rebuilding the front
jimny_IMG_20171110_185655
Having previously re-built the rear suspension it is time to sort the front. Again this is a KAP 3" lift with Pro-comp shocks and this is where the main "sag" is.
  8205 Hits
Tags:
More goodies arrive!
Jimny_IMG_20171109_210355
As we all get older things sag at the front, just ask anyone over 50! My Jimny is heavy and my old springs have worn out. However when compared to the new springs the old ones are actually longer! This is more about turns and wire diameter. The new ones have an extra turn and are made of 13mm wire compared to 11mm so I believe they will hold up rather than just compress and sag like the old ones. I can actually press the old ones by hand!
Still, there is a lot of weight up front so I decided to give the springs a fighting chance.
  7940 Hits
A quick test
IMG_20171107_191549
Having got the new tyres on the rims I could not resist a quick test. I still need to change the suspension on the front of the Jimny so it still looks a little wonky,  The rear suspension is complete so the wheels can go on and stay on. There looks to be sufficient clearance based on the cutting that was done for the previous tyres. I might h...
  9219 Hits
Tags:
New tyres
regal2250_IMG_20171106_155451
My new tyres arrived today. Maxxis Bighorn 235/85R16 which I put onto a set of Grand Vitara 16" Deep dish rims. Polish guy down the road popped them on for cash in hand. Looks like I might have to strengthen things in order to turn them :)
  10057 Hits
Tags:
