Gen 3 4wd switch/actuator fix
- julzonthetoolz
- Thank you received: 3
05 Nov 2024 08:44 #258195
by julzonthetoolz
Gen 3 4wd switch/actuator fix was created by julzonthetoolz
Hey everyone,
I've been chipping away at identifying the problem with my 4wd system (gen 3 push button) and finally made some progress.
Ive used the transmission operation guide and narrowed it down to a transfer box fault. Basically I'm getting the green light flashing 12 times with an audible click. Ive shorted the blue black wires and the hubs click in so seems that everything is working on that side.
I guess my question is how should I go about identifying and then fixing it? I have checked the wires and everything seems pretty solid. I must admit that I'm a little apprehensive to pull the actuator and switch off as I have zero experience with this sort of thing (gearboxes) and am unsure on where to start. Ive already spent good money on replacing vacuum components and would like to get to the bottom of it without wasting anymore.
Any logical guides/ comments are much appreciated.
Thank you kindly and have a great day.
- julzonthetoolz
11 Nov 2024 08:12 #258256
by julzonthetoolz
Replied by julzonthetoolz on topic Gen 3 4wd switch/actuator fix
Hey folks,
I ended up pulling off the actuator motor cover, its the round tin cover that hangs of the back end of the t-case. Inside I found that there was condensation and it was a little rusty. I left it off for a few days before I could get time enough to clean it up and put it back together by which time it had dried up. Just as a word of warning there are 2 springs inside which will fly out when you pull the armature out. If you are not patient and don't have small hands I would likely find someone else to do the job cause it is pretty fiddly getting it back together.
When I started up the vehicle it was in 4wd and from then on it has been working perfectly. I'm going to prioritise an oil change for the transfer case moving forward and hopefully this is the end of it.
Still not exactly sure what happened, maybe the armature was seized up or something but I hope that this helps somebody else who is having trouble.
Cheers,
Cheers,
11 Nov 2024 11:22 - 11 Nov 2024 11:28 #258258
Replied by yakuza on topic Gen 3 4wd switch/actuator fix
the procedure for putting the case back together and dismantling too was to put in 4wd and getting the mark on the little cog wheel inside there behind the triangle shaped lid at the actuator to be in the correct position.
can be found in the trail gear manual for low gears and most likely in the service manual too.
www.vegas4x4.com/sites/default/files/hyl...ion/304505-3-INS.pdf
Last edit: 11 Nov 2024 11:28 by yakuza.
- Twin Cam
01 May 2025 13:00 #260276
by Twin Cam
Replied by Twin Cam on topic Gen 3 4wd switch/actuator fix
4x4 Actuator positioning
I've a brand new activator for the t/f box. Anyone here got any info re correct positioning of the gear inside the box and the position the selector rod should be in
- Twin Cam
02 May 2025 13:02 #260291
by Twin Cam
The little mark on the cog wheel is a complete red herring
Its geared inside and outside and will go in in any position.
What's important is the position of the actuator relative to the selector shaft. I have Suzuki instruction for setting this if interested
- zambiannufty
18 Jul 2025 09:26 #261250
by zambiannufty
Replied by zambiannufty on topic Gen 3 4wd switch/actuator fix
Please please please share, been messing around with this thing for weeks. I oversee a small workshop for a NGO and my mechanics pulled it apart and can't figure out how to put it back together
Time to create page: 0.173 seconds
