Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
ARB air line repair
ARB air line repair
​When the rear axle was ripped off its mount it looks as if the air fitting for the ARB locker was damage. The air fitting consists of pipework fitted through what ARB call a bulkhead fitting. This has pulled out of the diff casing. ​The ARB was not fitted by me and I do not have the instructions. However Google shows that this fitting should be in...
  14370 Hits
