Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
First proper test run
jimny
We took a little test run out today, just a few green lanes around the area to see how she runs. The lanes are generally in very good condition around here following the local council putting down a loose surface on them a few years back. Therefore they are not taxing but there is enough mud and ruts to bounce the suspension around and to require 4...
  7319 Hits
Tags:
Interior refit
sized_Jimny_IMG_20171210_154635
 So with the MOT passed, we have been driving around this week. Unfortunately, there is a vibration or "push" in the drivechain. I took the rear propshaft off and found the UJs were notchy and very stiff. Taking them apart showed not only rusted out UJs but also a bent yoke. So a new yoke is on order and the car is back in bits in the garage. However this time is it only short lived and I took the opportunity to get on with the interior.
  7906 Hits
Tags:
Into the light!
Jimny_IMG_20171125_140126
​With everything coming together it is time to leave the garage for the first time in 4 years!
  7754 Hits
Tags:
A few more tweaks
regal2250_IMG_20171118_181938
When I started her up for the first time, I noticed a couple of problems. The first was the engine management light (EML) on whilst the second was a stream of water and clouds of steam from the exhaust.
  7834 Hits
Tags:
Wheel bearing
Jimny_IMG_20171121_184231
 Whilst re-building the front axle I noticed that the offside wheel bearing was really rough. It needed changing so off came the hub for a quick change. I originally documented a wheel bearing change HERE so this is more a quick update on changing it again.
  8606 Hits
Tags:
