Heavy Duty Transfer Box Rubber Mounts
sized_Jimny_IMG_20180130_190552
The standard Jimny rubber mounts are notoriously weak when the Jimny is used in anger offroad. It is common to break one, you find your transfer box lever suddenly leans to one side or the stick seems to disappear into the floor and everything shakes and rattles.
In the early days of modifying Jimny's, everyone developed Polybush style heavy duty mounts. Indeed I have a set of mounts which were early production models from Off-road armoury. However, the material used in Polybush items or variants is hard and unforgiving. Yes, it is long lasting and tough but it does not lend itself to comfort. That is why I got rid of my caster correction bushes in the radius arms and went back to rubber based ones, to improve the ride.
The same can be said of the transfer box. The heavy duty polybush style mounts on mine have lasted well but they transmit every vibration and bump onto the chassis and body work.
  10772 Hits
Tags:
Getting an identity
sized_Jimny_IMG_20180111_130503
I have had the Jimny over 10 years now and in that time it has never had any badges. When I purchased it there was no badges on it and I did not do anything about it.
  8924 Hits
Tags:
Centre Dot Fasteners
Jimny_IMG_20180108_123617
Not really a how-to, more a rant on the mis-use of these fasteners!
I have had my Jimny for 10 years so it was owned by others for 4-5 years before that. Up to now I have been giving it a hard time off-roading it so I have not been too concerned about the finer details of how it looked. However...
  9583 Hits
Tags:
Dual Battery monitor
dualbattery2
BigJimny has dual batteries fitted. A slightly enhanced standard battery for starting and a large battery in the boot for the winch. Having just replaced the batteries when rebuilding BigJimny, I decided to put a monitor in. A quick google showed a number of expensive systems but also a new cheap system from the Chinese discount sites.
  8660 Hits
Tags:
First proper test run
jimny
We took a little test run out today, just a few green lanes around the area to see how she runs. The lanes are generally in very good condition around here following the local council putting down a loose surface on them a few years back. Therefore they are not taxing but there is enough mud and ruts to bounce the suspension around and to require 4...
  7363 Hits
Tags:
