Interior refit
sized_Jimny_IMG_20171210_154635
 So with the MOT passed, we have been driving around this week. Unfortunately, there is a vibration or "push" in the drivechain. I took the rear propshaft off and found the UJs were notchy and very stiff. Taking them apart showed not only rusted out UJs but also a bent yoke. So a new yoke is on order and the car is back in bits in the garage. However this time is it only short lived and I took the opportunity to get on with the interior.
  7962 Hits
Tags:
Into the light!
Jimny_IMG_20171125_140126
​With everything coming together it is time to leave the garage for the first time in 4 years!
  7807 Hits
Tags:
A few more tweaks
regal2250_IMG_20171118_181938
When I started her up for the first time, I noticed a couple of problems. The first was the engine management light (EML) on whilst the second was a stream of water and clouds of steam from the exhaust.
  7887 Hits
Tags:
Wheel bearing
Jimny_IMG_20171121_184231
 Whilst re-building the front axle I noticed that the offside wheel bearing was really rough. It needed changing so off came the hub for a quick change. I originally documented a wheel bearing change HERE so this is more a quick update on changing it again.
  8709 Hits
Tags:
Axle breathers
As part of the rebuild I decided to fit my own axle breather kit. My Jimny has the old "hosepipe" style which was large, untidy and the hosepipes had hardened off over the years.
  8409 Hits
Tags:
