RockLobster Build - Part 2 - Building the gears
Processed-IMG_20191218_08453828
​This three part article covers my building of a RockLobster 6.5:1 transfer box. The article parts are:
  • Part 1 - Dis-assembly (see HERE)
  • Part 2 - Building the gears (this part)
  • Part 3 - Re-assembly. (see HERE)
The kit I am using (Trail Gear) contains gears and parts to replace/add to an SJ Transfer box. Within an SJ transfer box are effectively three gearsets/shafts as follows:
  • Input shaft - The Trail Gear set contains a replacement shaft to which you add either the original bearings or new bearings as you prefer,
  • Counter shaft - The Trail Gear set contains a replacement shaft and gearset to drop in,
  • Output shaft - The Trail Gear set contains replacement gears for the original gears, you either re-use the original bearings or new bearings as you prefer.
  12730 Hits
Tags:
Keithy's Trayback
20200110_183845
Has power been an issue for your Jimny?
It's not an issue here! Check out Keithy's Trayback build
See Read more...
  10164 Hits
Tags:
Differential Failure
Processed-IMG_20191108_190212-22
​Very shortly after we drove away from the 2019 BigJimny meet, I heard a very loud bang from somewhere underneath BigJimny. I pulled over and could not see anything, the Jimny still had drive but was giving out a knocking noise.
I suspected the CV joints as they have been clicking for a long time, however I found that the noise was coming from the rear diff (see video below, you can hear the knocking noise if you ignore the disc scraping noise)
  11825 Hits
Tags:
LittleJimny - Adding LED DRLs
74270814_3058491340891622_4303623136865157120_n
​The UK SZ5 specification Jimny has DRL (Daylight Running Lights) fitted. Whilst the main headlights on the SZ5 are LED, the DRLs are plain old Tungsten. Therefore they look yellow when on and are generally mis-matched to the overall look of the car. Therefore I have upgraded the lights to LED. It is a simple task of replacing the bulbs howeve...
  10725 Hits
Tags:
BigJimnyMeet 2019 - 20th October
After much planning the day of the event finally arrived. The last event was held a few years ago so it was definitely time to try again, so it was off to 4x4withoutaclub at Aldermaston.
​Sixty three Jimnys  were booked in making it possibly the largest Jimny gathering in Europe and even challenging the rest of the world. They came from all over the country with many staying ovenight at local hotels. Even the hotel car-park became its own mini-meet.
  11062 Hits
Tags:
