Fitting vented disks to a Gen3 Jimny
BigJimny_PXL_20201113_183458147
My Gen3 Jimny is so big and heavy it does not stop well. Whilst it does pass the MOT, I think the brakes need sorting so I have updated it to vented disks. Here is a quick video
  5639 Hits
Tags:
Fitting a Snorkel to a Gen4 Jimny
BigJimny_WhatsApp-Image-2020-09-18-at-08.16
With the Gen4 being a new Jimny and also being discontinued (hopefully temporary) in Europe, properly designed Snorkels are hard to come by. There are some "traditional" shaped ones appearing on the market from TJM and Chinese suppliers and a tubular one from Australia but only Mongolia and Brazil have snorkels shaped to match the design of the Gen4. The Brazilian ones are made for Suzuki in Brazil so are the "official" snorkel. However, Brazilian trading regulations make them hard to come by using the official channels. I have spent 6 months exploring the official route, with proper payments to Suzuki and proper export and finally got my hands on some. Here is the fitting video!
  6466 Hits
Tags:
Fitting an ARB Difflocker to a Gen3
BigJimny_IMG_20200611_200854
2020 was a strange year and I have not published much to this front page. Here are some catch-ups. First of all, fitting a Diff Locker.
  5376 Hits
Tags:
Modifications and Upgrades to our Gen4 Jimny
Resized_IMG_20200504_185045
Over the past few months I have been carrying out some little modifications/upgrades to our Gen4 Jimny and created some video guides.......
  11632 Hits
Tags:
RockLobster Build - Part 1 - Dis-assembly
Processed-IMG_20191212_1944062
I have embarked on building my own low ratio transfer box. I have previously built two boxes, one for my SJ and one for my Jimny but both of these were 4:1 boxes built using the "Difflock" cut & shut gears. This is a frequently maligned process but the current Jimny one has served nearly 10 years so far so they cannot be too bad, however with 32" tyres it is time for something more low range.
Since I did the cut & shut one, a variety of aftermarket gearsets have appeared that provide a "drop in" solution with pre-cut gears. There are a variety available from cheap Chinese versions through to Japanese manufactured ones made in the original factory.
I went for the Trail-Gear 6.5:1 set as it represents a mid priced solution that has been on sale in the USA for a number of years. This should bring back the gearing quite nicely on the road whilst providing a very low gearing off-road.
Also needed is a Suzuki SJ transfer box, either a 410 or 413 will do (except for the very early 410 versions which are useless). See the section in the Wiki - HERE - which tells how to identify the correct box. Late 413 boxes are particularly good as they have the same larger flanges that the Jimny has, however it is straight forward to drill the old ones if necessary.
If you are doing this from scratch you will also need mounting arms, propshafts and a speedo adaptor to fit it to a Suzuki Jimny. Of course, I already have those parts on my as it has a 4.1:1 Transfer box already fitted.
So the build begins......BigJimny's Transfer box.
  21112 Hits
Tags:
